You've already seen our coverage of apps optimized for Nvidia's CUDA technology. Now we're taking a look at the performance of AMD's Stream framework, which was recently revamped in a Catalyst 9.5 driver hotfix. We even sneak in an interview with ATI. Read more
We recently had the chance to play a bit of Cryostasis, the latest title supporting Nvidia's PhysX technology. In fact, we played the game on five different hardware configurations. Want to play this one? We'll tell you what you need in order to enjoy it. Read more
Hard drive capacities have increased in large increments over the last few years, while trends indicate reduced spindle speeds of 5,400 RPM instead of 7,200. We looked at three generations of Samsung hard drives to analyze the performance ramifications. Read more
This month, ATI's new Radeon HD 4770 is missing in action, since online stores are not only unable to keep it in stock, but also de-listing it completely. With violent movements in pricing, though, it'd have been taken off the recommended list anyway. Read more
Archived from groups: alt.comp.hardware.overclocking (More info?)
hi all
I currently own a P4 1.7 Northwood 512 kb cache, with 512 SDR Ram, the
M/B has a FSB of 400mHz.
I 'd like to upgrade my system by getting a M/B that will support DDR
Ram, but i'd like to keep my P4 1.7 for now. If I buy a 533mHz or 800
mHz M/B will my processor be compatible? Might it be possible to
overclock it using the 533 setting to 2.26 gig (ie 133mHz x 17 = 2.26
instead of 100 mHz x 17 = 1.7 mHz) or have I got the wrong end of the
stick?
thanks for looking
Gaz
"Gaz" <gazoc7@aol.com> wrote in message
news:93c86c54.0405212030.4672a38e@posting.google.com...
> hi all
> stick?
> thanks for looking
My P4 1.8 400 runs flawlessly at 533 for 2.4 with stock heat sink and fan.
Quixote
>> stick?
Never heard of a Northwood 1.7, so it's likely a 1.75V 256kb cache version
limited to ~2.0GHz (Williamette?). There's nothing of the sort on Intel's
s-spec page for P4's - all 1.7's are 256kb, 0.18um (none are 512kb,
0.13um)...
We HAVE been at war with Iraq for 13 years now, bombing their
country on at least a weekly basis.
"U.S.-led sanctions have killed over a million Iraqi citizens,
according to UN studies" - James Jennings
3,000+ innocent Iraqi civilian casualties can't be "wrong"...
Gaz wrote:
> hi all
> stick?
> thanks for looking
> Gaz
Unless Intel snuck out some undocumented processor that can't be a
Northwood as the slowest (documented) Northwood is 2 gig.
were the 1.6A and 1.8A designated as something other than Northwoods, by
Intel?
yep, your both right, I double checked and it's only got 256bk of L2 cache.
so I'm stuck with 2 gHz at best?
Gaz
> Gaz
Well, no, I wouldn't say you're necessarily 'stuck' with 2 gig. A look at
the overclockers database indicates that 2.2 might be a reasonable target
and there's even one posted at 2.5, supposedly with the stock Intel cooler,
but you can't always trust what someone claims. The average was about 2.1.
Well, sad to say, what you have is not a 'Northwood' Pentium 4 (the one
with the 512 KByte L2 cache), but a 'Williamette' Pentium 4 with a 256
Kbyte L2 cache and a 0.18 feature size rather than the 0.13 feature size of
the 'Northwood'. It is not worth spending money trying to upgrade a system
and and still use that CPU, especially if you intend to overclock ( a
'Willamette' Pentium 4 is VERY limited in top clock speed, and the smaller
L2 cache is a real bottle neck.)
You are in the position of needing to replace the memory, CPU, AND
motherboard to get back on the step by step upgrade path. Since ANY
reasonable upgrade is going to require new memory and a new motherboard,
that is certainly the place to start, but don't let the compatibility
requirements of your present CPU limit your future path. A 'Prescott' 2.4
GHz Pentium 4 currently has the lowest price among Pentium 4 CPU's (a
'Northwood' 2.4 GHz and a 'Prescott' 2.8 GHz CPU are about the same price, ~
$175 US [both with 800 MHz FSB.]) You could expect to spend at least $175
US for an overclocking friendly motherboard and 512 MBytes of generic
PC3200 DDRAM.
Phil Weldon, pweldonatmindjumpdotcom
For communication,
replace "at" with the 'at sign'
replace "mindjump" with "mindspring."
replace "dot" with "."
> hi all
> stick?
> thanks for looking
> Gaz
of
system
smaller
I have a 1.8 Williamette CPU which I run at 1.98 (4x110) and it is fine and
stable. I have tried to go above 2ghz but I get an instant crash (using
Easytune). Something thats been bothering me is my manual says the board is
a 400FSB but it has FSB settings all the way up to 133. Does this mean I can
run a 533FSB CPU? The max multiplyer is 24 and the board is a GA-8ITXE with
an i850 chipset.
Any feedback greatly appreciated.
Cheers,
Spizz
the willy is a 423 pin the 533 northys are 478 pin.
WRONG. Williamettes came in both pinouts.
Depends on the motherboard. If your RDRAM is PC800, it will not overclock
by 33%, so you would have to be able to use the async memory setting (5:4
ratio for FSB:memoryclock.) In fact, memory speed might be your limit even
with a .200/1.8 = 11.1% increase for PC800.
For communication,
"spizz" <spizz_uk@hotmailDOT.com> wrote in message
news:WX%rc.29$0P4.16@newsfe5-win...
> of
> system
> smaller
and
is
can
with
> an i850 chipset.
> Cheers,
> Spizz
(5:4
even
Thanks for the info. The ram is PC800, i'll play it safe and just keep
looking out for a 2.4 with 400FSB. Oh and the CPU is 478 pins.
Cheers,
Spizz
A Pentium 4 2.4 GHz with a 400 MHz FSB is $180 US at
http://www.zipzoomfly.com .
Yeah, I know it is a flaky name, but they were once called 'googlegear', and
I think google.com complained. I've bought memory, motherboards, CPU's, and
hard drives from them and had good experiences.
Then you can get THAT Pentium 4 2.4 above 3 GHz using the 3:4 ratio and
PC800 overclocked only 12.5% even at 3.2 GHz, so the memory speed of your
current PC800 will likely not limit your CPU speed.
I have a Pentium 4 1.6A running at 2.4 GHz using using PC800 and that
method. Basically the FSB is running at 4/3 X 1.125 X 100 MHz X 4 = 600
MHz, while memory is running at the equivalent of an FSB speed of 450 MHz,
just a 12.5% overclock.
For communication,
"spizz" <spizz_uk@hotmail.com> wrote in message
news:2hce57Fass32U1@uni-berlin.de...
overclock
> (5:4
> even
> Cheers,
> Spizz
and
is
can
with
> an i850 chipset.
> Cheers,
> Spizz<
If you are using win98 classic, you are limited to speeds less than 2.2 GHz.
At that speed it will refuse to load a driver due to a divide-by-zero error.
and
and
MHz,
Great info Phil, thanks. I've saved it for future reference when I do
finally pick up one of these critters. I'd ordered a 2.4 400FSB CPU from
PCBuyers.co.uk for £70 yesterday but they called this morning and said
they're out of stock. $180 US is tempting but out of reach atm at over
£100. I'll keep a look out for a 2nd hand one.
Incidentally, do you think that a Celeron 2.4 will out pace my 1.8
Williamette running at 1.98 and how are they for overclocking? They are nice
and cheap at about £50 but will it give any significant boost?
Cheers again,
Spizz
That Celeron and the rest of its family has only a 128 Kbyte L2 cache, and
thus has a severe limition on its performance. You'd be much wiser to look
for a 'pulled' Pentium 4 2.4 GHz with a 400 MHz FSB. The price and
availablity of a new 2.4/400 is likely because they are no longer made (my
guess.)
For communication,
news:2hdul5Fbq2bmU1@uni-berlin.de...
> and
> and
your
> MHz,
nice
> Cheers again,
> Spizz
> and
> is
> can
> with
>>an i850 chipset.
>>Cheers,
>>Spizz<
Only if you don't get the patch for it. There is a patch for that just as
there was for the win95 350MHz divide by zero problem.
"David Maynard" <dNOTmayn@ev1.net> wrote in message
news:10b3ue7qe5e0e0b@corp.supernews.com...
> > and
board
> > is
> > can
> > with
> >>an i850 chipset.
> >>Cheers,
> >>Spizz<
GHz.
error.
> there was for the win95 350MHz divide by zero problem.<
True, there is a patch but getting it requires a call to MS and may involve
a trouble-call fee. I heard the patch only works for two weeks anyway so I
did not mention it.
"Phil Weldon" <notdisclosed@example.com> wrote in message news:<hMQrc.6264$be.1338@newsread2.news.pas.earthlink.net>...
> PC3200 DDRAM.
hi Phil
Thats the conclusion I've come to myself, so I've managed to justify a
new computer to myself!!!
2600 Barton
Ati 9700 SE 128 MB
512 DDR Ram
....and while I'm at it a 160 gig hard drive
Gaz
>>>and
> board
>>>is
>>>can
>>>with
>>>>an i850 chipset.
>>>>Cheers,
>>>>Spizz<
> GHz.
> error.
> a trouble-call fee.
You can find it on download sites, although not easily.
> did not mention it.
Sounds like an old wives tale.
Phil
What do you mean bt "Pulled"? I'm back in the OC game and assuming a
2.4/400 is a good candidate?
thx
bob
> cache, and thus has a severe limition on its performance. You'd be
> much wiser to look for a 'pulled' Pentium 4 2.4 GHz with a 400 MHz
> FSB. The price and availablity of a new 2.4/400 is likely because
> they are no longer made (my guess.)
>>> 'googlegear', and I think google.com complained. I've bought
>>> memory, motherboards, CPU's, and hard drives from them and had
>>> good experiences.
>>> ratio and PC800 overclocked only 12.5% even at 3.2 GHz, so the
>>> memory speed of your current PC800 will likely not limit your CPU
>>> speed.
>>> that method. Basically the FSB is running at 4/3 X 1.125 X 100 MHz
>>> X 4 = 600 MHz, while memory is running at the equivalent of an FSB
>>> speed of 450 MHz, just a 12.5% overclock.
>> do finally pick up one of these critters. I'd ordered a 2.4 400FSB
>> CPU from PCBuyers.co.uk for £70 yesterday but they called this
>> morning and said they're out of stock. $180 US is tempting but out
>> of reach atm at over £100. I'll keep a look out for a 2nd hand one.
>> are nice and cheap at about £50 but will it give any significant
>> boost?
>> Cheers again,
>> Spizz
"Pulled": removed from an discarded computer system; used. A Pentium 4
2.4 400 MHz is more likely to be found used that Pentium 4 CPUs with a
faster clock speed and/or faster bus speed.
For communication,
"Bob Snelgrove" <steelgtr_95127@yahoo.com> wrote in message
news:afudnaw_us6YFSHdRVn-uQ@comcast.com...
> Phil
> thx
> bob
> >>> good experiences.
> >>> speed.
> >> boost?
> >> Cheers again,
> >> Spizz
There are 548 identified and unidentified users. To see the list of identified users, Click here.
