G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.abit,alt.comp.hardware.overclocking,alt.comp.hardware.pc-homebuilt (More info?)
I have a IC7-MAX3 motherboard and a P4 3.2C Northwood CPU. Using the
Motherboard's Voltage Measurement tool from the BIOS setup menu, I
noticed that:
Vcore measures 1.5V even though it is set (by default) to 1.55V. Now
if I adjust the setting to 1.60V then Vcore measures 1.55V. So it
appears that there is a 50mV difference between Vcore(set) and
Vcore(measured).
I am wondering what to make of this. There are a few possibilies:
1. Vcore measurement is not accurate. It is actually higher than
measured and is probably correct in actuality.
2. Vcore measurement is accurate. But due to high load, Vcore
(measured) will always be slightly lower than Vcore (setting). So what
I am observing is normal and expected. Vcore(measured) is reading what
is normally expected (50mV lower than where it is set at).
3. The Vcore regulation is off and is slightly low. That is although
Vcore is set to 1.55V, there is an -50mV "offset" in the regulation
scheme. Thus in order to compensate, making Vcore (setting) = 1.6V is
the way to go to make Vcore (measure)=1.55V which is the specified
typical Vcore needed.
So what is happening?
Thanks!
(Please respond here. Email is invalid)
noticed that:
Vcore(measured).
Thanks!
