Archived from groups: alt.comp.hardware.overclocking (More info?)
Hello, I'm a first time water cooler.
I just finished installing a Swiftech H2-8600
(http://www.swiftnets.com/products/h20-8600-0.asp) kit in a Lian-Li PC60
case.
I had a Thermalright 900U with a 120mm fan on an Abit IC7 mainboard with a
P4e 2.8 at 3.37.
Installation went fine. Although ambient is a bit high today (its hot a
muggy here in the north East), idle temp is fairly high. Certainly higher
then with the air cooler at about 50ºc with 1.4v. Running games, folding and
such them is in the mid 60's which is about as high as it got on air.
The only positive is that sound is MUCH lower which was the reason why I
went with a water cooler.
I have the pump going directly into the water block (Swiftech 6000P) --> out
into the radiator (mounted in the front of the case exhausting out the
front) --> out to the Northbridge (MCW20) cooler then up to the bleeder and
then down to the pump again.
I can add a second radiator if necessary but would rather not.
http://208.185.94.62/pics/WaterCooling001.jpg
http://208.185.94.62/pics/WaterCooling003.jpg
http://208.185.94.62/pics/WaterCooling011.jpg
case.
P4e 2.8 at 3.37.
