Bad luck with water cooler pumps.
  • Overclocking
  • Cooling
Anonymous
a b K Overclocking
July 7, 2004 4:55:09 AM
Archived from groups: alt.comp.hardware.overclocking (More info?)
I don't know what the problem is. But,in the last year or so,I've have three
water pumps screw up on me.Two different brands too. Two are ViaAqua
1300's(good pumps I thought).
It starts with nasty grinding noise from the pump then gets progressively
worse. Now,my pump doesn't start all the time when I give it power. I'll
usually have to give the reservoir a bang on the desk to get it started. What's
happening to these things?There isn't much to them.Are they repairable? I use
distilled water and a small amount of water wetter.Thanks,Dawg
More about : bad luck water cooler pumps
Anonymous
a b K Overclocking
July 7, 2004 4:55:10 AM
three
What's
use
I'm not familiar with ViaAqua pumps, but after years of saltwater fish
tanks, I can tell you that 95% of all of the pumps on the market are cheap
pieces of junk. Maxijets are about the cheapest you'll get into reliable
pumps, but an Eheim is going to be even more preferable. Until your pump's
rating is in horsepower, there aren't many decent-quality options - and even
in the larger, more expensive pumps, there are still a bunch of pieces of
junk.
steve
Anonymous
a b K Overclocking
July 8, 2004 1:44:15 AM
Thanks Steve,
But don't these things last longer than 4-6 months? What is breaking or causing
the grinding,seizing?Is it the water wetter additive? These mag pumps don't
seem that complicated. I took one apart and didn't see anything obvious.
Anonymous
a b K Overclocking
July 8, 2004 1:44:16 AM
> Thanks Steve,
Depending on the brand, the answer could be anything from "no" to "maybe".
don't
Unfortunately, that is something that I can't tell without looking at it.
: ) I doubt that it's the water wetter. Take a good look at the impeller,
and take a good look at the bearing surfaces, and look for grit, dirt, or
pieces of plastic/metal/corrosion/whatever.
steve
Anonymous
a b K Overclocking
July 9, 2004 1:25:30 AM
On the pump I took apart,I did notice a white film of stuff on the "barrel".
Looked like lime or calcium.But,how could that be?I used distilled water.
>steve
Anonymous
a b K Overclocking
July 11, 2004 6:58:33 PM
"YanquiDawg" <yanquidawg@aol.com> wrote in message
news:20040708172530.06753.00001196@mb-m13.aol.com...
"barrel".
it.
impeller,
> >steve
How about the shaft the impeller rides on? It might be worn thin, which
makes the impeller looser, causing it to fail to start unless tapped, and
will make a decent amount of noise. 4-6 months sounds about right for those
tyoes of impellers. I went through the same thing with our fish tank. We had
two pumps running, and they usuall lasted about that long. What you want is
a better quality pump, with a different type of impeller setup.
Good Luck!
BB
Anonymous
a b K Overclocking
July 13, 2004 1:49:19 AM
Okay,so who makes good water pumps.Eheim? And who else?? Thanks,Dawg
>What you want is
>Good Luck!
>BB
Anonymous
a b K Overclocking
July 13, 2004 6:33:46 PM
Eheim are the best, I don't see the point in looking elsewhere. (I was a
commercial tropical fish breeder for years and a hobbyist all my life),
Eheim are unbeatable for reliability and longevity. I have tried many other
brands, trying to save money. It's false economy, especially in
mission-critical applications like water cooling a CPU.
~misfit~
>> What you want is
>> Good Luck!
>> BB
Anonymous
a b K Overclocking
July 14, 2004 1:51:19 AM
"~misfit~" <misfit61nz@yahoo-mung.co.nz> wrote in message
news:QRHIc.10349$LT3.389012@news.xtra.co.nz...
other
> ~misfit~
> >> What you want is
> >> Good Luck!
> >> BB
I've had very good luck with a Supreme Mag Drive pump in my pond, and it's
on it's third year now. Then again, I don't think that you are looking for
950 gallons an hour. I recommend the Ehiem and Supreme magdrive lines.
MC
