Tom's Hardware > Forum > Overclocking > General Discussions > Problem with PCChips M848ALU and Athlon XP 3200+
Forum Overclocking : General Discussions - Problem with PCChips M848ALU and Athlon XP 3200+
Archived from groups: alt.comp.hardware.overclocking (More info?)
I have purchased two PCChips M848ALU motherboards, and are having a
problem with each of them. It seems to work OK with an AMD Athlon XP
2100+ processor, but not with an AMD Athlon XP 3200+ processor. If I
use the 3200+ it will only power on if the jumper (JP1) has been
cleared, and then reset. If I then reboot, nothing comes up on the
screen.
I have updated the motherboard with the latest firmware, but still
have the same problem.
I have tried another 3200+ processor, and I am having the same
problem.
Anyone got any ideas ??
Thanks in advance,
Daniel
Sponsored Links
"Daniel" <news@djbnet.co.uk> wrote in message
news:add5e2f8.0409091420.471cfed6@posting.google.com...
> screen.
> problem.
Junk / return the boards. Even when PCChips boards work theres a massive
preformance hit.
www.overclockers.co.uk have a spakle nForce2 for £30 GBP
hamman
Reply to Anonymous
Not Junk.....
I've built a number of machines in recent years based on PCChips boards.
They're cheap and unexciting - but they do the job. They don't have the
bells, whistles or manuals :o) that other manufactures offer. But who reads
the manual anyway? And (as a "for instance" ) I think that IR and Firewire
will have come and gone without me ever have used or fitted one of these
devices... :o)
Regarding the OP question: did you check that the M848ALU supports 200FSB
Barton cored XP's.....?
..... didn't think so.
Pete
"Hamman" <none@example.com> wrote in message
news:F-CdnSi2DfQ4ZNzcRVn-sQ@eclipse.net.uk...
>> screen.
>> problem.
> preformance hit.
> hamman
Reply to Anonymous
"Immuno" <immunodevice@yahoo.com> wrote in message
news:ci2jal$jve$1@hercules.btinternet.com...
> Pete
Hi Pete,
Yes, it does - Managed to get it work by manually setting the the ratio for
CPU/Memory.
Don't you mean 400FSB ?? - Or is that just another way of putting it ?
Thanks
Daniel
Reply to Daniel
Didn't say it couldn't :o)
But as you've found out, it only suports a FSB of 200MHz by manually
overclocking.
Pete
"Daniel" <djb2002@gmx.net> wrote in message
news:2qkuumF10l0qbU1@uni-berlin.de...
>> Pete
> Hi Pete,
> for CPU/Memory.
> Thanks
> Daniel
Reply to Anonymous
There are 1067 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
