Are we approaching a physical barrier of the CPU speed?
Archived from groups: alt.comp.hardware.overclocking (More info?)
The electromagnetic waves in conductor have a limited speed of about
v=2*10^8 m/s.
The area of the common chip is about 1 cm^2, so we can assume that
electromagnetic wave has to pass about
s=10^-2 m
inside chip.
I will not take relativistic mechanic, because electromagnetic waves
have fixed speed. From
t=s/v
we have time required that signal comes from one side of the chip to
the another side is
t=0,5*10^-10 s
Taking f=1/t
we get that at 20 GHz signal can not even travel from one side of the
chip to another one before arrival of the new clock signal.
If we take average size of one motherboard, here we have a road of
about 10 cm. This means that motherboard clock can not go beyond 2
GHz.
Intel promissed 30 GHz CPU in 2017, with smaller transistors, but
bigger number of them (as usual). Therefore it is not to be expected
that overal size of the CPU chip will be much reduced.
I could conclude that future CPU will work with several clocks. For
example at 30 GHz will work only ALU and some registers, where L1 RAM
cache will drop to 5 GHz and RAM to less than 2 GHz. This means a lot
of wait states, and a very weak effect of the clock raising.
23 answers Last reply
More about approaching physical barrier speed
  1. Archived from groups: alt.comp.hardware.overclocking (More info?)
    not really, the only problem with the 90nm process is the prescotts design.
    Dothans (based on P3 design) can hit 2ghz with ease with the 90nm proccess,
    and only produce 24watts of heat output. Hardly the ceiling of cooling.
    These CPU's do more work per mhz than the P4 so infact BEAT it in some
    tests, and also beat the A64 in some tests too. So the future of CPU's???
    MORE work per mhz, not less like the P4 design, thats where intel went
    wrong, and a few of us knew that from the start, but was called amd fan
    boyz.........
    fact is if you find out that sooner rather than later your going to run out
    of clockspeed head room, you DONT design the CPU to do less work per mhz now
    do you? Well thats what they did, instead of fixing the P3's problems, they
    designed a new chip that did very little work per mhz, and everyone thought
    it was great it could do 1.4-1.8ghz, shame a 1.1ghz P3 utterly thrashed it
    and the AMD 1.4ghz made the P4 look like the new celeron...
    I for one cant wait for the "old" P3 design intel chips to surface in the
    desktop market. then maybe AMD could drop the "rating" of there chips.
    From Adam Webb, Overlag
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.768 / Virus Database: 515 - Release Date: 22/09/2004
  2. Archived from groups: alt.comp.hardware.overclocking (More info?)
    <snip>
    Optical processors are in development (search on bbc tech news) and should
    provide somewhat higher speeds.
    Further on, we should be seeing organic / biological processors... they you
    really could kill your pc!
    hamman
  3. Archived from groups: alt.comp.hardware.overclocking (More info?)
    The limit is perhaps one of rising R&D per performance gain, but that
    has long been with us. The issue will be whether we can maintain the
    requisite rising revenue to fund it. Intel along with many IT companies
    are as much low single-digit growth vehicles, not the old 30-40%/yr.
    Yes the P-M architecture is good - based on the P3s quiet development
    for industrial & other applications re low thermal power, good CPU power.
    Ramping clock to outperform the disadvantages of longer pipelines was
    the story of the P4 - ie, achieving less per clock but ramping clock faster.
    The future seems to be a mix of also achieving more per clock a la P3.
    It was easy in the past to get a 10x increase in performance by the
    benchmarks on an upgrade - so at least perceptible in real world :-)
    That is getting more difficult:
    o CPUs have very high bandwidth, as does memory
    o HDs have much quicker too - but are still electromechanical
    ---- density has greatly increased, rotational latency less so
    The real problem with HDs based-I/O is in the realised throughput:
    o As years have gone by we moved away from few-app file & 1 data-file
    o Today we have MS-IE & such like with vast numbers of tiny files
    o Lots of seeking & multiple accesses stress the mechanical speed issue
    The mechanical speed issue is still a major barrier - not just CPU speed.
    Ability to re-order commands (TCQ/NCQ) will help, but as yet whilst the
    market has HD drives offering it - cards & O/S up the chain do not yet.
    Dorothy Bradbury
    www.stores.ebay.co.uk/panaflofan for quiet Panaflo fans & other items
    www.dorothybradbury.co.uk (free delivery)
  4. Archived from groups: alt.comp.hardware.overclocking (More info?)
    "Samir Ribic" <samir.ribic@alemsistem.com.ba> wrote in message
    news:f9e33c87.0409240500.1a31680@posting.google.com...
    > v=2*10^8 m/s.
    > s=10^-2 m
    > inside chip.
    > t=s/v
    > the another side is
    > t=0,5*10^-10 s
    > Taking f=1/t
    > GHz.
    Again an assumption that has two potential flaws. It ignores the
    possibility that getting smaller wont go through a quantum jump beyond
    adding more transistors.
    Then there's the possibility that I've been reading about on some scifi
    sites about extra-dimensional processing...well in the mean time maybe we'll
    just settle for the 3rd.
    All that assumes that the entire chip in synchronously clocked. Obviously
    an dubious assumption.
    Currently the clear physical barrier seems to be KW per acre and that
    translates directly into horsepower per peck in the future. Maybe the
    watercooled OCers aren't such nuts after all.
  5. Archived from groups: alt.comp.hardware.overclocking (More info?)
    "Adam Webb" <adam@ajmysecondname.eclipse.co.uk> wrote in message
    news:GOudnTtEbYXxgMncRVn-oQ@eclipse.net.uk...
    design.
    proccess,
    > boyz.........
    out
    now
    > do you?
    Did ya come up will multi core too?
  6. Archived from groups: alt.comp.hardware.overclocking (More info?)
    yup...multi core comes under "more work per mhz" in my mind ;-)
  7. Archived from groups: alt.comp.hardware.overclocking (More info?)
    Do you really think it matters?
    The 'transistors" of the most powerful computer,
    the human brain, switch in milliseconds.
    Even when clock speeds hit a wall, more transistors
    will give us massively parallel microprocessors that
    will continue to do more work in the same amount
    of time than their predecessors.
    > v=2*10^8 m/s.
    > s=10^-2 m
    > inside chip.
    > t=s/v
    > the another side is
    > t=0,5*10^-10 s
    > Taking f=1/t
    > GHz.
  8. Archived from groups: alt.comp.hardware.overclocking (More info?)
    I'd put my money on silicon carbide devices as being in real world
    applications before optical. Organic and bio-processors are still only at
    the stage of being really great ways to part funding organisations from
    their money in order to fund academic research.
    Pete
    "Hamman" <none@example.com> wrote in message
    news:nOCdnfSmKpuf8MncRVn-qw@eclipse.net.uk...
    > <snip>
    > you really could kill your pc!
    > hamman
  9. Archived from groups: alt.comp.hardware.overclocking (More info?)
    "Immuno" <immunodevice@yahoo.com> wrote in message
    news:cj4d6p$c0$1@sparta.btinternet.com...
    What the hell ever happened to diamond?
  10. Archived from groups: alt.comp.hardware.overclocking (More info?)
    "spinlock" <NullVoid@att.net> wrote in message
    news:2rlrr1F1b3gbvU1@uni-berlin.de...
    That's is entirely NOT clear. Define "switch" in the context of the brain
    and then relate that to the concept of "switch" is current digital
    electronics.
    > > v=2*10^8 m/s.
    > > s=10^-2 m
    > > inside chip.
    > > t=s/v
    > > the another side is
    > > t=0,5*10^-10 s
    > > Taking f=1/t
    > > GHz.
  11. Archived from groups: alt.comp.hardware.overclocking (More info?)
    > electronics.
    His analogy may employ a fair amount of poetic license but the gist of it
    is correct.
    >>>v=2*10^8 m/s.
    >>>s=10^-2 m
    >>>inside chip.
    >>>t=s/v
    >>>the another side is
    >>>t=0,5*10^-10 s
    >>>Taking f=1/t
    >>>GHz.
  12. Archived from groups: alt.comp.hardware.overclocking (More info?)
    "David Maynard" <dNOTmayn@ev1.net> wrote in message
    news:10lc6viqvbjrh2b@corp.supernews.com...
    brain
    > > electronics.
    > is correct.
    That's the issue that I would argue. We(humans) do NOT yet have a clear
    picture of what processing in the context of a neuron means. To suggest
    that something switches in a brain that is in ANY fashion comparable to a
    current digital systems assumes facts NOT in evidence and further there's
    some considerable reason to suspect that it is NOT comparable.
  13. Archived from groups: alt.comp.hardware.overclocking (More info?)
    > brain
    >>>electronics.
    >>is correct.
    True
    > To suggest
    Well, we do know enough to know that electro-chemical signals do, 'in some
    fashion', 'switch' in neural cells, we just don't understand the totality
    of it nor the organizational structure (not to imply that's in any way
    'trivial').
    > and further there's
    That is the point in noting the incredibly slow, by electronic switching
    terms, the 'brain cell' is yet how infinitely more complex in computational
    ability the brain is vs a computer using those 'fast' circuits. Clearly the
    'suggestion' is that it operates on an entirely different computing principle.
    The broader suggestion is that total computational power may not be
    necessarily limited by 'slow' switching times (e.g. processor 'MHz') if
    more advanced techniques are employed.
    This is similar to the 'sound barrier' argument. It's certainly problematic
    if one assumes propeller driven aircraft is the only means to accomplish
    it... but then... maybe we could design a new type of aircraft.
  14. Archived from groups: alt.comp.hardware.overclocking (More info?)
    news:10lcdivs7um82fc@corp.supernews.com...
    > > brain
    > >>>electronics.
    it
    > >>is correct.
    > True
    > > To suggest
    a
    > 'trivial').
    > > and further there's
    computational
    the
    principle.
    Precisely and therefore not comparable.
    No, since nothing really is known about comparable switching time then we
    don't know "slow". Some chemical state changes make 100 ps switch times
    look turtlelike. Some apparent timing in the millisecond region could be a
    result of a zillion vastly faster digital OR analog operations.
  15. Archived from groups: alt.comp.hardware.overclocking (More info?)
    >>>brain
    >>>>>electronics.
    > it
    >>>>is correct.
    >>True
    >>> To suggest
    > a
    >>'trivial').
    >>>and further there's
    > computational
    > the
    > principle.
    Not showing much imagination there.
    The current understanding of it doesn't comport with your 'could be'
    speculation.
  16. Archived from groups: alt.comp.hardware.overclocking (More info?)
    we
    be a
    > speculation.
    Nope, it "comports" precisely with my claim from the getgo which is that
    mostly it is all unknown and therefore not comparable.
  17. Archived from groups: alt.comp.hardware.overclocking (More info?)
    > we
    > be a
    >>speculation.
    There's a lot more known about it that you give credit for.
    Which is neither here nor there because he's simply pointing out that there
    are ways of increasing computing power other than simply counting cycles of
    the same old thing.
  18. Archived from groups: alt.comp.hardware.overclocking (More info?)
    I believe Best Data Products acquired three brands from the former Diamond
    Multimedia Company including Diamond Stealth and Viper graphics cards as
    well as Diamond SupraMax modems.
    http://www.diamondmm.com/index.php
    :o))))))))))))))))))))
    "Ron Reaugh" <rondashreaugh@att.net> wrote in message
    news:PMk5d.431788$OB3.322612@bgtnsc05-news.ops.worldnet.att.net...
  19. Archived from groups: alt.comp.hardware.overclocking (More info?)
    news:UOk5d.431798$OB3.97495@bgtnsc05-news.ops.worldnet.att.net...
    > electronics.
    Actually, it is quite clear. Go to Google and search on "neuron switch"
    > > > v=2*10^8 m/s.
    > > > s=10^-2 m
    > > > inside chip.
    > > > t=s/v
    > > > the another side is
    > > > t=0,5*10^-10 s
    > > > Taking f=1/t
    > > > GHz.
  20. Archived from groups: alt.comp.hardware.overclocking (More info?)
    news:J1q5d.633469$Gx4.349912@bgtnsc04-news.ops.worldnet.att.net...
    > brain
    > > > electronics.
    it
    > > is correct.
    It is clear that a neuron has inputs, an ouput, and a threshold function
    that determnines when the output goes active based on the state of the
    inputs.
    Digital circuitry is EXACTLY the same.
  21. Archived from groups: alt.comp.hardware.overclocking (More info?)
    news:2roqpcF1b4qh9U1@uni-berlin.de...
    brain
    > > electronics.
    No, that tells nothing relevant to this issue.
  22. Archived from groups: alt.comp.hardware.overclocking (More info?)
    news:jOG5d.636343$Gx4.108045@bgtnsc04-news.ops.worldnet.att.net...
    > brain
    > > > electronics.
    Finding and analyzing data from places like web.mit.edu
    is not relevant???? LOL!!!!
    OK dude, enjoy life inside your tiny mind!
  23. Archived from groups: alt.comp.hardware.overclocking (More info?)
    news:2roqv0F1c65voU1@uni-berlin.de...
    > > brain
    > > > > electronics.
    > it
    > > > is correct.
    a
    there's
    > inputs.
    No, that model is at its basest infancy. First of all the time domain of
    the inputs are not established nor is the possibility that an input might be
    serialized. A few Neanderthal experiments have been done on the simplest
    cases. Output vs outputs has not been established.
Chip CPUs Overclocking
