Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have XP Home and XP Media Edition 2005. I already have them sharing a
wireless internet connection, but, I cannot make them network to each other
or the printer. The printer is also on a printer server in order to make it
ethernet compatible with the wireless router. Both computers are wireless to
the router. The networking wizard does not help at all. How do I fix this??
On Sun, 15 May 2005 20:49:39 -0700, CelebrityX23
What, exactly, are they doing or not doing?
Provide ipconfig information for each computer, as a start.
1) Start - Run - "cmd".
2) Type "ipconfig /all >c:\ipconfig.txt" into the command window.
3) Open Notepad, make sure that Format - Word Wrap is NOT checked!.
4) Open file c:\ipconfig.txt from Notepad.
5) Copy and paste entire contents of the file into your next post.
6) Identify operating system (by name, version, and Service Pack level) with
each ipconfig listing.
7) Please don't munge or omit any detail, as a case like yours will best be
resolved with details.
Cheers,
Chuck
http://nitecruzr.blogspot.com/ Paranoia is not necessarily a bad thing - it's a normal response from experience.
My email is AT DOT
actual address pchuck sonic net.
Now I am even more frustrated. The info you gave me earlier only worked on
one of them. I even had to change it to get it to work. Here is some
information that might be of assitance.
Old PC: Windows XP Home Edition SP2
New PC: Windows XP Media Center Edition 2005 SP2 ( pro)
Both of them recognize each other by name in "cmd" with actual IP addresses
With MCE 2005, this is the only info that is missing or marked as "no"
Windows IP Configuration
Host Name . . . . . . . . . . . . : rachie022480
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
> Cheers,
> Chuck
> http://nitecruzr.blogspot.com/ > Paranoia is not necessarily a bad thing - it's a normal response from experience.
> My email is AT DOT
On Mon, 16 May 2005 22:53:29 -0700, CelebrityX23
So exactly what content do you get in c:\ipconfig.txt on both computers? I can
help you a lot more if you'll provide what's needed.
What did you have to change to get it to work?
Cheers,
Chuck
My email is AT DOT
