Archived from groups: alt.comp.hardware.overclocking (
More info?)
Try the "AquaStream"-Pum from www.aquacomputer.de
This pump is specially for use in computers. i have it, it works great!
"Satan's Little Sister" <littlesisterNO@SPAMsofthome.net> schrieb im
Newsbeitrag news:mnh0o05neshv6ojiugqf4bra5ev1j3scpr@4ax.com...
> Thus spake YanquiDawg:
>>>My question is I am thinking about running my computer 24/7 like I use
>>>to do. But now I have water cooling, is running the water cooling 24/7
>>>a bad thing?
>>Well, most water pumps don't last very long anyway so you'll probably have
>>to
>>change it out more often.I went through 3 in 2.5 years with the pump only
>>running 1/2 a day every day.
> What kind of pump were you using? I had a small fountain pump get
> noisy after six months of 24/7 (still works though). But a bigger
> better fountain pump (Beckett was the make I think) has been running
> great for nearly three years and my Swiftech MCP600 has been on nearly
> continuously for around two years.
> If you have quality parts, 24/7 is no big deal. If you have cheap
> part, their limited life span will be used up soon.
> sls
