G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking (More info?)
Hi,
I have ABIT BD7II-RAID MotherBoard. Recently I upgraded my CPU from P4
1.7GHz (FSB400) to
P4 3,06 (FSB533).
I own two identical sticks of Kingston Value RAM PC2100, so DDR266, both
512MB, 1024 in total.
The basic configuration CPURAM (1:1) works fine. But I would like to set
it to 3:4, like in the case of the older P4 1,7 CPU (it was FSB100, and DRAM
was
working with 133, so 3:4).
I have the latest BIOS version.
When i set DRAM Ratio H/W Strap to LOW and DRAM Ratio (CPURAM) to 3:4
computer starts (POST gives me info that DRAM is working on 133/178) but no
Windows is lunched, i just get blue screen and automatic restart (blue
screen with some error codes i cant even read and fast restart).
What is happening? How can i overclock the RAM to work correctly.
I didnt play with voltages. Should I?
Can i BURN anything when playing with it?
I am not a real overclocker but i want to get all my RAM can serve me (so,
use 3:4 ratio). My first guess is that this Kingston Value RAM cannot work
on 350MHz?
Best regards and
I wish You a Merry Christmas and a Happy New Year.
Michal Byrczek
Hi,
1.7GHz (FSB400) to
P4 3,06 (FSB533).
was
on 350MHz?
Best regards and
Michal Byrczek
