Beginner in need of help
Archived from groups: alt.comp.hardware.overclocking (More info?)
Hi all,
I'm wondering about all this over clocking stuff. I'm a complete
beginner with this.
I've built a few PCs, my PC at the moment is of the following spec:
Jetway P4X400DAZ motherboard, VIA chip set.
Pentium4 2400 MHz
1536Mb (1.5Gig) RAM - 2 sticks of Kingston PC3200 400MHz 512Mb, and 1
stick of unknown make PC3200 400MHz 512Mb. I'm assuming they're running
at 400MHz as they should?!
Sapphire Radeon 9550 256Mb Graphics Card
Maxtor 60gig HD, and a Fujitsu 13Gig HD
Samsung Combo Drive DVD ROM / CD Writer
Samsung 16x DL DVD Writer All formats.
In cooling, i have the genuine Intel heatsink, and a cheap LED fan in
the case side.
any more details required?
I was wondering how I go about over clocking? is it easy to do, what
would i O/C to? etc etc
Thanks in advance guys
Mark
1 answer Last reply
More about beginner help
  1. Archived from groups: alt.comp.hardware.overclocking (More info?)
    "MarkThommo" <MarkThommo_84@ntlworld.com> wrote in message...
    > I'm wondering about all this over clocking stuff. I'm a complete beginner
    > with this.
    As always, the answer is to read, experiment and read some more.
    > Pentium4 2400 MHz
    Is this a 400MHz, 533MHz, 800MHz, Prescott, Northwood CPU, what?
    > 512Mb, and 1 stick of unknown make PC3200 400MHz 512Mb.
    That's a bit of an odd combination. You may also find it limits the
    overclockability of your system, depending on what CPU you're running.
    > I'm assuming they're running at 400MHz as they should?!
    You're far better placed to test that assumption than we are. If the board
    is any cop, the POST screen should tell you the memory frequency. If it
    doesn't, there are plenty of OS level utilities that will.
    You overclock the CPU by raising the front side bus speed. However, doing so
    will also alter the memory frequency. You must find the best compromise of
    CPU and memory voltages, frequencies, timings and so-on.
    > is it easy to do,
    That largely depends on the feature set provided by your boad. Jetway
    products are generally regarded as being more of the cheap and cheerful ilk
    than the overclocker's first choice.
    Provided your board gives you the options you need, it's easy to do provided
    you are methodical, only changing one setting at a time and making a note of
    the performance and stability.
    > what would i O/C to?
    That is an impossible question to answer, and the only person in a position
    to do so is the person with first-hand access to the PC - i.e. you.
    Richard Hopkins
    Cardiff, Wales, United Kingdom
    (replace nospam with pipex in reply address)
    The UK's leading technology reseller www.dabs.com
Overclocking
