G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking (More info?)
Hi,
I have a P-4 with hyperthreading and an MSI motherboard that supports
800Mhz FSB
I have two Nanya 256Mb RAM sticks that are PC3200 with cas 3-3-3-8
according to CPU-Z and the BIOS
The FSB is at 200Mhz (effective 800Mhz) according to CPUZ and the BIOS
Unfortunately I can’t get the Nanya RAM anymore and I am wondering if I
add the following:
http://www.kustompcs.co.uk/acatalog/info_5233.html
Crucial PC3200 DIMM 256mb
Crucial PC3200 CAS3 RAM, for use in DDR Based systems at up to 200Mhz FSB.
Whether this will be compatible (with 3-3-3-8) timing and also allow me
to keep my 800Mhz front side bus?
Hi,
800Mhz FSB
add the following:
