Archived from groups: alt.comp.hardware.overclocking (More info?)
I am trying to upgrade an Intel D815EEa with a 1.2 Piii and Upgradeware
adaptor, but it has been crashing.
This board, similar to one in a Dell Dimension 4100, has been tested to
work with both the PowerLeap and Upgradeware adaptors. In my case, the
board runs fine with an 800mhz Piii. I have experienced instability when
using the adaptor/1.2 combo, even with the specified Bios P10.
I believe it's must be hardware related, using the adaptor and a 1.2 Piii.
I have
swapped the adapters and 1.2's from my Compaq in an effort to see if it's a
particular adapter, a particular CPU, and no difference. Same for memory
(different speeds, brands, etc..), power supply, hard drives, even
motherboards... no luck. Yet both claim it should work...
The reason I believe it's hardware is because when the system does go dead
(lights on) or BSOD, it might take minutes, unplugged, before it will go
back on again. Or even a clearing of the CMOS.
It's running fine at 800... but I wish I could resolve the issue....
You guys are experts in this area, can you give me some insight as to where
to look, adjustments to make to the Bios, etc, which has been cleared... and
left at it's defaults, which are automatic,.... thank you!
B'Regards,
Vinnie
> I have
Just a thought... is the voltage too high? causing it to overheat, then
taking a few minutes to cool down before it will power up again? Or is
the heatsink properly mounted? I seem to remember that adaptor was a
PITA to mount the heatsink and CPU into.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Good question... I believe all is well with the fan/heatsink. I have the
same set up in my Compaq, no problems...I could double check... it is very
tight....
The adapter is supposed to correct voltage.. is there a way, software wise,
to check or even adjust?
"Pat" <no@spamplease.com> wrote in message
news:42a07f9c$1_1@spool9-west.superfeed.net...
>> Piii. I have
>> a
>> dead
>> where to look, adjustments to make to the Bios, etc, which has been
>> cleared... and left at it's defaults, which are automatic,.... thank you!
> taking a few minutes to cool down before it will power up again? Or is the
> heatsink properly mounted? I seem to remember that adaptor was a PITA to
"Uncle Vinnie" asks "The adaptor is supposted to correct voltage.. is there
a way, software wise, to check or even adjust?"
The following are just suggestions, as I am not familiar with the adapter
nor the motherboard.
An Intel CPU sets its default core voltage with logic levels present at
certain pins; the adapter changes the default core voltage by intercepting
the pins and presenting different logic levels to the CPU socket on the
motherboard. As I remember, the adapter also provides Vcc to pins on the
CPU that would not be supplied from the motherboard (also by intercepting
the pins from the motherboard socket. Unless there are jumpers on the
adapter (or unless there is installable software provided with the adapter)
you won't be able to vary the Vcc voltage provided by the adapter.
If the motherboard has a chip that monitors parameters like supply voltages,
CPU voltage, CPU temperature, motherboard temperature, fan speeds, etc.,
then software like MotherBoard Monitor can display the readings in Windows,
either on request, or on the right side of the task bar.
If, as it seems, you have an Intel motherboard, don't expect much in the way
of available adjustments. Intel motherboards are designed and constructed
to be very stable... but also to accept only specified CPUs with no
changable parameters. I once had an Intel motherboard that would accept
Celerons without L2 caches, but not those with. Intel never issued any BIOS
update to allow use of anything but the original two Celeron models.
Consequently I have never since purchased an Intel motherboard. I suspect
you just may be out of luck.
Phil Weldon
"Uncle Vinnie" <vinrin57@nospam.optonline.net> wrote in message
news:7U2oe.5210$HP1.2772@fe08.lga...
> tight....
>>> when using the adaptor/1.2 combo, even with the specified Bios P10.
>>> Piii. I have
>>> it's a
>>> memory
>>> dead
>>> you!
>> the heatsink properly mounted? I seem to remember that adaptor was a PITA
I just came across something.. could it be the cpu is overheating???? I also
found something, go into BIOS and change the settings from automatic, to '3'
(versus '2'), this is uncharted territory for me.. does it make sense??
"Phil Weldon" <notdiscosed@example.com> wrote in message
news:GZ3oe.15002$w21.2132@newsread3.news.atl.earthlink.net...
> there a way, software wise, to check or even adjust?"
> intercepting the pins and presenting different logic levels to the CPU
> socket on the motherboard. As I remember, the adapter also provides Vcc
> to pins on the CPU that would not be supplied from the motherboard (also
> by intercepting the pins from the motherboard socket. Unless there are
> jumpers on the adapter (or unless there is installable software provided
> with the adapter) you won't be able to vary the Vcc voltage provided by
> the adapter.
> voltages, CPU voltage, CPU temperature, motherboard temperature, fan
> speeds, etc., then software like MotherBoard Monitor can display the
> readings in Windows, either on request, or on the right side of the task
> bar.
> way of available adjustments. Intel motherboards are designed and
> constructed to be very stable... but also to accept only specified CPUs
> with no changable parameters. I once had an Intel motherboard that would
> accept Celerons without L2 caches, but not those with. Intel never issued
> any BIOS update to allow use of anything but the original two Celeron
> models. Consequently I have never since purchased an Intel motherboard. I
> suspect you just may be out of luck.
> Phil Weldon
>> very tight....
>>>> Piii. I have
>>>> it's a
>>>> memory
>>>> dead
>>>> go
>>>> you!
Investigation is the way to go, but I can't comment intelligently without
further knowledge. Perhaps if you could answer a few questions;
Is your motherboard produced by Intel? I ask because the indentification
you gave is so close to an Intel chipset name.
Directions, settings, and descriptions vary greatly from BIOS to BIOS. Not
only are there more than one BIOS manufacturer, but motherboard
manufacturers choose what the BIOS displays and what modifications to make.
Is there any further description of exactly what the choices of 'automatic',
'3', and '2' actually DO, included in the manual?
What operating system do you use? Windows 2000 and Windows XP generate
low-power-consumption-instructions what the CPU is idle; consequently the
CPU is unlikely to over heat when not loaded by tasks, and should not be
overheating, even with a poor cooling solution.
About the 'overheating' possibility. If the problem IS overheating, it
should not take several minutes to cool off before being able to boot up
again. You should be able to reboot almost immediately, as the heat stored
in the CPU is very small. Is there no report of the 'CPU temperature' in
the BIOS? This reading in the BIOS is not too useful, as the CPU does not
generate very much heat before the operating system is loaded.
People who use this newsgroup tend not to have Intel motherboards, so to get
much in the way of help, if you DO have an Intel motherboard, you need to
give a lot more information to get help.
Phil Weldon
news:l1hoe.39776$NZ1.5855@fe09.lga...
>also found something, go into BIOS and change the settings from automatic,
>to '3' (versus '2'), this is uncharted territory for me.. does it make
>sense??
>> the adapter.
>> bar.
>> issued any BIOS update to allow use of anything but the original two
>> Celeron models. Consequently I have never since purchased an Intel
>> motherboard. I suspect you just may be out of luck.
>> Phil Weldon
>>> the same set up in my Compaq, no problems...I could double check... it
>>> is very tight....
>>>>> Upgradeware adaptor, but it has been crashing.
>>>>> to
>>>>> the
>>>>> Piii. I have
>>>>> it's a
>>>>> memory
>>>>> dead
>>>>> go
>>>>> you!
Hi, the board is indeed an Intel D815EEA. Using XP Home. Bios is Intel
Bios P10. I am not sure what the number signify- 2, 3, Automatic- It has
something to do with configuring SDRam, as follows: CAS latency- 3,2,Auto,
RAS to CAS 3,2,Auto, RAS Precharge, 3,2, Auto.
I have left everything as Auto...
Because I have had the same problems on 2 different boards, 2 different
adapters, 1.2 piii's, Power Supplies, it is not any one broken item. What
frustrates me is that in all cases, the board may take minutes to restart...
where the cpu fan may not go on, or the power light might not.. I would
think this might be something overclockers might recognize...
Thanks Phil... your insight is greatly needed and appreciated!
news:6Umoe.15388$w21.8279@newsread3.news.atl.earthlink.net...
> Not only are there more than one BIOS manufacturer, but motherboard
> make. Is there any further description of exactly what the choices of
> 'automatic', '3', and '2' actually DO, included in the manual?
> stored in the CPU is very small. Is there no report of the 'CPU
> temperature' in the BIOS? This reading in the BIOS is not too useful, as
> the CPU does not generate very much heat before the operating system is
> loaded.
> get much in the way of help, if you DO have an Intel motherboard, you need
> to give a lot more information to get help.
> Phil Weldon
>>sense??
>>> "Uncle Vinnie" asks "The adaptor is supposed to correct voltage.. is
>>> adapter nor the motherboard.
>>> the adapter.
>>> bar.
>>> would accept Celerons without L2 caches, but not those with. Intel
>>> never issued any BIOS update to allow use of anything but the original
>>> two Celeron models. Consequently I have never since purchased an Intel
>>> Phil Weldon
>>>> is very tight....
>>>>>> to
>>>>>> the
>>>>>> Piii. I have
>>>>>> it's a
>>>>>> memory
>>>>>> dead
>>>>>> go
>>>>>> you!
>>>>> then taking a few minutes to cool down before it will power up again?
>>>>> Or is the heatsink properly mounted? I seem to remember that adaptor
>>>>> was a PITA to mount the heatsink and CPU into.
I haven't used that particular board but it sounds suspiciously like the
Vcore regulator can't handle the load and is OC shutting down. Which would
not be terribly surprising because the Tualatins draw more current, at a
lower voltage, than the board was originally designed for. And it would be
even worse if the adapter is setting Vcore too high. And then there's the
issue of what the Vcore reg is interpreting the setting as since it may not
have been originally designed to know what those low Vcore settings mean
(so it may put out nothing, or default to the lowest thing it knows, which
would be too high).
Have you put a meter to it and checked Vcore?
>>loaded.
>>Phil Weldon
>>>sense??
>>>>the adapter.
>>>>bar.
>>>>Phil Weldon
>>>>>is very tight....
>>>>>>>to
>>>>>>>the
>>>>>>>Piii. I have
>>>>>>>it's a
>>>>>>>memory
>>>>>>>dead
>>>>>>>go
>>>>>>>you!
I have not put a meter to it however I have a few programs... Intel's
Monitor as well as CPUZ, Sandra, CPUID...
I know software isn't the best way to tell...
"David Maynard" <nospam@private.net> wrote in message
news:11abivbt3dro08f@corp.supernews.com...
>> 3,2,Auto, RAS to CAS 3,2,Auto, RAS Precharge, 3,2, Auto.
>> What frustrates me is that in all cases, the board may take minutes to
>> restart... where the cpu fan may not go on, or the power light might
>> not.. I would think this might be something overclockers might
>> recognize...
> not have been originally designed to know what those low Vcore settings
> mean (so it may put out nothing, or default to the lowest thing it knows,
> which would be too high).
>>>loaded.
>>>need
>>>Phil Weldon
>>>>automatic,
>>>>sense??
>>>>>Vcc
>>>>>(also
>>>>>provided
>>>>>the adapter.
>>>>>task
>>>>>bar.
>>>>>the
>>>>>Phil Weldon
>>>>>>is very tight....
>>>>>>>>to
>>>>>>>>the
>>>>>>>>Piii. I have
>>>>>>>>it's a
>>>>>>>>memory
>>>>>>>>go
>>>>>>>>dead
>>>>>>>>will
>>>>>>>>go
>>>>>>>>to
>>>>>>>>you!
David.... in researching, you name is everywhere, you are the guru!! Thank
you!
If this is the case, and it make sense, how are both PowerLeap and
Upgradeware claiming it works? In Upgradwares case, I tried 2 adapters/
CPU's, same results.
I wonder about a few things, which I am trying to find out- was it tested to
work under XP/ SP2, also, doesn't XP incorporate their own software version
of something Intel added (idling/stepping something like that...?), and, is
there software or even BIOS settings that might better control the CPU
and/or memory?
news
2lpe.9037$hg.8865@fe12.lga...
>>> has
>>> recognize...
>> would not be terribly surprising because the Tualatins draw more current,
>> at a lower voltage, than the board was originally designed for. And it
>> would be even worse if the adapter is setting Vcore too high. And then
>> there's the issue of what the Vcore reg is interpreting the setting as
>> since it may not have been originally designed to know what those low
>> Vcore settings mean (so it may put out nothing, or default to the lowest
>> thing it knows, which would be too high).
>>>>without
>>>>indentification
>>>>the
>>>>as
>>>>loaded.
>>>>need
>>>>Phil Weldon
>>>>>automatic,
>>>>>sense??
>>>>>>at
>>>>>>Vcc
>>>>>>(also
>>>>>>are
>>>>>>provided
>>>>>>by
>>>>>>the adapter.
>>>>>>task
>>>>>>bar.
>>>>>>the
>>>>>>CPUs
>>>>>>Phil Weldon
>>>>>>>it
>>>>>>>is very tight....
>>>>>>>>>tested
>>>>>>>>>to
>>>>>>>>>the
>>>>>>>>>instability
>>>>>>>>>1.2
>>>>>>>>>Piii. I have
>>>>>>>>>if
>>>>>>>>>it's a
>>>>>>>>>memory
>>>>>>>>>go
>>>>>>>>>dead
>>>>>>>>>will
>>>>>>>>>go
>>>>>>>>>issue....
>>>>>>>>>to
>>>>>>>>>thank
>>>>>>>>>you!
>>>>>>>>again?
> you!
Well, I looked at the upgradeware listing and it doesn't contain much
information, other than to use the P10 BIOS. By that I mean, what processor
was used in the 'test'? I also don't know if there are multiple revisions
of that board and, if so, which one was tested.
I do note that they tend to speak in terms of the celeron tualatins and
while one might presume the P-III version should work too there could still
be some differences. Not saying there definitively is but it's something to
consider (current draw, cache initialization, etc), especially since you
have a problem.
Maybe P2B will see this and jump in because he's put a number of Tualatin
P-IIIs on Asus P2B motherboards.
You're probably thinking of the microcode update but that's done by the
BIOS and there won't be any updates done by a BIOS that can't identify the
processor and which stepping it is. And the odds that Intel just tossed the
tualatin codes in on a motherboard not made for them is next to nil.
> and, is
> and/or memory?
Well, it's possible that relaxing some BIOS parameters, in particular
memory, might improve the stability. The Tualatin is actually operating out
of spec even with the adapter and I've noted that some boards simply can't
run memory at the otherwise 'normal' settings. The timing gets skewed
because of the not-quite-right bus levels.
I don't recall you describing just exactly how the 'instability' manifested
itself. What was the error and is there anything that reliably recreates it
on demand? Such as something 3D meaning AGP is active (memory again)?
I also run my celeron tualatins at slightly increased Vcore, mainly because
I'm also overclocking them but it might improve stability at normal speed
too. OTOH, it might make it worse, in your case, if it's a regulator
current limit issue.
> processor was used in the 'test'? I also don't know if there are multiple
> revisions of that board and, if so, which one was tested.
I have an email in to upgradeware asking for those specifics....
> still be some differences. Not saying there definitively is but it's
> something to consider (current draw, cache initialization, etc),
> especially since you have a problem.
>> to work under XP/ SP2, also, doesn't XP incorporate their own software
>> version of something Intel added (idling/stepping something like
>> that...?),
> the tualatin codes in on a motherboard not made for them is next to nil.
Actually, SpeedStep, sorry? Does that help? Maybe finding a way to
disable it in XP?
>> and, is there software or even BIOS settings that might better control
>> the CPU and/or memory?
> out of spec even with the adapter and I've noted that some boards simply
> can't run memory at the otherwise 'normal' settings. The timing gets
> skewed because of the not-quite-right bus levels.
As far as I can tell, the only meaningful chances I can make in BIOS would
be changing all of the memory settings from Auto to '3', which is what the
memory sticks are anyway.
> manifested itself. What was the error and is there anything that reliably
> recreates it on demand? Such as something 3D meaning AGP is active (memory
> again)?
It is random.. it will work for a day, then go down... I might plug
something into the USB port and get BSOD. There is nothing listed under
Eventvwr.
To date, the only decent error message I got from XP's online crash analysis
is regarding BIOS- I had BSOD. Microsoft online crash analysis came back
"unable to identify problem but system bios does not support your processor'.
Runs fine with an 800mhz Piii!
> because I'm also overclocking them but it might improve stability at
> normal speed too. OTOH, it might make it worse, in your case, if it's a
> regulator current limit issue.
OK. Let's hope they actually know, and respond.
>>>that...?),
> disable it in XP?
Tualatins don't have the P4 built in 'throttling'. Any throttling would be
the traditional motherboard ACPI power management stuff. But, even so, I
don't see how that could create a problem.
Try it. But that's also just CAS and there should be some others, unless
Intel is hiding them and basing them off CAS or SPD. If I remember
correctly seems to me that precharge was particulalry problematic on my BH6s.
Just move all memory timings to the max value available.
>>again)?
Of course, since those are the worst to trouble shoot.
Have you run memtest (DOS)?
> I might plug
I'm not sure what to make of that since USB can be problematic even on a
'working' system.
> Eventvwr.
One would hope so since it was made for them.
David:
I changed all the SRAM setting in Advanced Bios from Auto to 3. If it runs
stable with the 800 for a few days, I'll go back and revisit the 1200 with
the adapter.
One item I was wondering about is regarding power. APM is enabled for BIOS
power management, as well as ACPI, which XP Home is using...
Should both be enabled under BIOS, especially since XP is only using ACPI?
Thanks!
news:11aenjn7u07arae@corp.supernews.com...
>>>>tested to work under XP/ SP2, also, doesn't XP incorporate their own
>>>>software version of something Intel added (idling/stepping something
>>>>like that...?),
>>>the processor and which stepping it is. And the odds that Intel just
>>>tossed the tualatin codes in on a motherboard not made for them is next
>>>to nil.
>> disable it in XP?
>> would be changing all of the memory settings from Auto to '3', which is
>> what the memory sticks are anyway.
> BH6s.
>>>(memory again)?
>> I might plug something into the USB port and get BSOD.
> 'working' system.
>> There is nothing listed under Eventvwr.
>> analysis is regarding BIOS- I had BSOD. Microsoft online crash analysis
>> came back "unable to identify problem but system bios does not support
>> your processor'.
David Maynard wrote:
>> Thank you!
>> adapters/ CPU's, same results.
> multiple revisions of that board and, if so, which one was tested.
> Tualatin P-IIIs on Asus P2B motherboards.
Not much I can add, since I've never experienced stability problems with
any of the numerous P2B systems I've upgraded to Tualatin P3s with
Upgradeware slot adapters, and I have not used their S370 adapters.
However, running the Tualatin at 1.3v Vcore usually provokes
instability. It could be that 1.3v is just too low for the processor,
but may be due to Vcore ripple - it reads 1.3v on a DMM, but looks ugly
on an oscilloscope. It's possible the OP's problem is ripple, but
unlikely he has a scope to check.
P2B
>> like that...?),
> to nil.
> reliably recreates it on demand? Such as something 3D meaning AGP is
Uncle Vinnie wrote:
> David:
> the adapter.
A slower CAS timing shouldn't introduce any instability. It's simply slower.
No. Turn off the APM, unless there's some feature to only it you need, like
auto power up at some specified time.
> Thanks!
>>>>>like that...?),
>>>>to nil.
>>>disable it in XP?
>>BH6s.
>>>>(memory again)?
>>'working' system.
>>>your processor'.
>>> Thank you!
>> and while one might presume the P-III version should work too there
>> could still be some differences. Not saying there definitively is but
>> it's something to consider (current draw, cache initialization, etc),
I agree that 1.3V would be a problem but they're not rated to be 1.3 volt
Vcore. Did I miss something?
> P2B
>>> like that...?),
>> the BIOS and there won't be any updates done by a BIOS that can't
>> identify the processor and which stepping it is. And the odds that
>> Intel just tossed the tualatin codes in on a motherboard not made for
>>> control the CPU and/or memory?
>> operating out of spec even with the adapter and I've noted that some
>> boards simply can't run memory at the otherwise 'normal' settings. The
>> timing gets skewed because of the not-quite-right bus levels.
>> a regulator current limit issue.
Isn't this adapter supposed to supply the correct voltage?
This particular board is the only one that I've had trouble with...
Upgradware's 370 works great in my Compaq 5000, and Powerleaps slot works
great in my Dell XPS-T450 (440BX), as well as their Neo in my Dell L400
(although my only complaint here has to do with Dell- this is an Intel board
that can run at 100mhz, and Dell has it locked at 66..)
With so many successes.... !
news:11akileb4d85o87@corp.supernews.com...
>>>> Thank you!
>> However, running the Tualatin at 1.3v Vcore usually provokes instability.
>> It could be that 1.3v is just too low for the processor, but may be due
>> to Vcore ripple - it reads 1.3v on a DMM, but looks ugly on an
>> oscilloscope. It's possible the OP's problem is ripple, but unlikely he
>> P2B
>>>> like that...?),
>>> to nil.
>>>> guru!! Thank you!
>> with any of the numerous P2B systems I've upgraded to Tualatin P3s
>> with Upgradeware slot adapters, and I have not used their S370 adapters.
>> ugly on an oscilloscope. It's possible the OP's problem is ripple, but
> volt Vcore. Did I miss something?
The P2B series VRM provides a nice, flat output down to about 1.6v,
after which ripple increases markedly as output voltage is lowered. How
much Vcore ripple can a Tualatin tolerate? No idea, but if the OP's VRM
regulates any worse than a P2B's at Tualatin voltages, it may well
provoke instability.
P2B
>>>> like that...?),
>>> The timing gets skewed because of the not-quite-right bus levels.
No, it just allows you to set the CPU voltage requested from the
motherboard. Powerleap adapters have onboard voltage regulators which
replace the motherboard's regulator, Upgradeware adapters do not.
You appear to have encountered a compatibility issue on this one. Have
you run CPU-Z to see if the BIOS is initialising the processor caches
correctly?
http://www.cpuid.org/cpuz.php
In some cases you can flash an Intel BIOS to overcome Dell limitations.
>>>>>Thank you!
>>>P2B
>>>>>like that...?),
>>>>to nil.
No, there is no regulator or power source on it. The tualatin is still
making a Vcore request to the motherboard regulator just as any processor
(such as your P-III) normally would.
The el-cheapo adapter I use has jumpers to change the Vcore selection,
albeit an undocumented feature you have to trace out on your own to
discover. But I didn't see jumpers in the upgradeware picture so I imagine
is feeding the default setting through.
I discovered the feature when trying to find out why the Vcore setting I
was wrapping directly on the processor pins wasn't taking. The dern adapter
was over-riding them.
That certainly suggests it's the board that's the problem.
If it's an Intel board you can often flash the corresponding Intel BIOS
into them.
>>>>>Thank you!
>>>P2B
>>>>>like that...?),
>>>>to nil.
>>>>> guru!! Thank you!
>>>> much information, other than to use the P10 BIOS. By that I mean,
>>>> what processor was used in the 'test'? I also don't know if there
>>>> are multiple revisions of that board and, if so, which one was tested.
>>>> but it's something to consider (current draw, cache initialization,
>>>> etc), especially since you have a problem.
>>> but unlikely he has a scope to check.
Yes. I suspect it's a Vcore problem too. I was just wondering why 1.3 came
up as the tualatin should not be asking for 1.3. Should be 1.45 to 1.5, or
so. Although, the 1.45 probably gets interpreted as 1.4 since pre-tualatin
boards don't know about the 50mv pin.
If it was mine I'd try changing it, either by adapter jumper or processor
pin wrap, to 1.6 (1.7 if done by pin wrap).
> P2B
[snip]
>> How much Vcore ripple can a Tualatin tolerate? No idea, but if the
>> OP's VRM regulates any worse than a P2B's at Tualatin voltages, it may
>> well provoke instability.
> came up as the tualatin should not be asking for 1.3. Should be 1.45 to
> 1.5, or so. Although, the 1.45 probably gets interpreted as 1.4 since
> pre-tualatin boards don't know about the 50mv pin.
Sorry, I appear to have confused the issue :-(
I normally run my Tualatin P3-S processors at their lowest stable Vcore.
On a P2B, that's usually 1.4v, sometimes 1.35v. They will usually load
the OS and idle at 1.3v, but crash under load - presumably because Vcore
is too low, or too unstable. Given what I see on the scope, I suspect
the latter.
BTW, it's the 25mV pin older boards don't know about.
> processor pin wrap, to 1.6 (1.7 if done by pin wrap).
>> P2B
> [snip]
>>> may well provoke instability.
>> to 1.5, or so. Although, the 1.45 probably gets interpreted as 1.4
>> since pre-tualatin boards don't know about the 50mv pin.
> the latter.
I see. Ok, that makes sense.
Yeah, I realized that after I pressed the send key.
Always works that way, don't it? See the mistake after send.
>>> P2B
'David Maynard' wrote, in part: "Always works that way, don't it? See the
mistake after send."
That's because if we saw them BEFORE the send, they wouldn't be mistakes
B^). The same reason that when you find something it is always in the last
place you look!
Phil Weldon
news:11anastogm31ie0@corp.supernews.com...
>> [snip]
>> is too low, or too unstable. Given what I see on the scope, I suspect the
>> latter.
>>>> P2B
> B^).
hehe. Of course. That's the 'joke' of it
> place you look!
As George Carlin pointed out, why the hell would you keep looking after you
found it?
My father (no relation to George Carlin) was a master comic of the obvious,
such as those, and would drive my grandmother crazy with them. I remember
riding in the car when she, as driver, was complaining "This is ridiculous.
I've had to stop at every red light between home and the airport" to which
my father pointed out "mom, you're *supposed* to stop at the red ones.
'Green' is for 'go'."
Invariably she'd reply "oh, you know what I mean."
Of course he did. hehe
> Phil Weldon
>>>[snip]
>>>latter.
>>>>>P2B
I wanted to get back to you about the following:
First, thank you very much for all you help...I greatly appreciate it. To
date, Upgradware support NEVER replied to my last email for specifics- how
they claim the adaptor works with the 815EEA board, what BIOS settings, etc.
But worse, I may have lost my 1.2 pii to heat exhaustion. I left my Compaq
running in my attic/office- temp had to hit 100+ (f, not c!).
The 1.2/adapter from the Intel (which this thread concerns) was immediately
used for the Comapq.
When I have a chance, I will swap to see what actually went- the piii or the
adapter...
Not good... and as much as I want to get the Intel boad running with the
1.2, it makes no sense to run and replace either part (piii or adapter)
since I have been unsuccessful getting them to work since day 1. For now,
my 11 year old is happy with her 800mhz and that's all she cares about...
I'll have to get back to you folks... yet another setback! Oh well...
>> [snip]
>> latter.
>>>> P2B
Well, oddly, all works... no clue why swapping processors would make a
difference, but both processors/adapters do work..
On to the next step.. give you guys some of the info from CPU-Z... I'll get
that to you shortly...
Back on track!!
news
dAre.21918$So7.17193@fe10.lga...
> etc.
> Compaq running in my attic/office- temp had to hit 100+ (f, not c!).
> immediately used for the Comapq.
> the adapter...
>>> [snip]
>>> the latter.
>>>>> P2B
It's probably the reseating that did it.
> Back on track!!
> news
>>etc.
>>the adapter...
>>>>[snip]
>>>>the latter.
>>>>>>P2B
There are 1000 identified and unidentified users. To see the list of identified users, Click here.
