Ok I've narrowed down my problem between mamewah and mame to mamewah.
after creating all the ini files for all of my games, when i launch
them in mamewah, the games are too small and don't fit the entire
screen. When I launch the games from mame, i.e.; mame sf2 or mame mk ,
the game launches beautfilly with resolutions looking optical. I assume
this has to do with a configuration change in one of mamewahs ini. any
help would be appreciated. thanks alot.
cast thought about it a bit, then said...
Actually, it may be that MAMEwah doesn't have your MAME path set
correctly, and thus isn't getting to the mame.ini or game .ini files.
MAMEwah can be a real pain to get configured properly, but there is a
utility out there that can help (helpfully named MAMEwah Config ;-)
I figured out what I had done wrong. In the properties windows of the
program, i set it to emulate windows 95. I changed it to default and it
worked great. thanks alot guys.
