Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hi !
Are there any specific requirements to get XP show wireless connexion
configuration parameters ?
I'm under XP-Pro (sp2) on a laptop, and after installing a wireless PC
card (SMC-2632W), I note that the "Network connections" panel doesn't
have any wireless related funtion listed in the left hand menu.
Moreover, in the connections list, the SMC card appears as a regular
network connexion. For example, displaying the connexion status shows
the status, duration and connexion speed but no signal strength as we
may expect with a wireless connexion.
Finally, in the system tray, the connexion's icon is a regular
connexion (two computers) instead of a wireless one (a computer with
waves), and when the signal goes weak, it displays a "cable
disconnected" notification !
Perhaps the software installed with this card, disabled the functionlality of Windows.
Ask their support how to fix this.
--PA
"Michel S." <NoSpam@msn.com> wrote in message news:mn.a2bc7d55cedddbd8.32962@msn.com...
> Hi !
> Where's the problem ??
> Thanks..
