Power Supply Problem??
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I took apart a power supply to clean it; looked like it ran inside a vaccuum
cleaner bag.
When I hooked it back up, the power will come on for a few seconds, and the
fans in the power supply and on the chip start, but about the time the POST
test should start, everything shuts down. What would do this?
I never removed a power supply before; could I have missed hooking up
something? There's a wide plug into the mobo, and power to the drives. Any
help appreciated. Thanks
2 answers Last reply
More about power supply problem
  1. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    > cleaner bag.
    Disconnect all of your drives (and I mean ALL.) Leave just your MB connected.
    Does your power supply now start? AT or ATX?
  2. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    "TANKIE" <tankie@aol.com> wrote in message
    news:20040403144546.07753.00000614@mb-m18.aol.com...
    vaccuum
    > cleaner bag.
    How did you clean it???? Did you use a brush, vacuum cleaner, or what????
    Did you use an anti-static wrist strap or ground yourself to your case while
    you worked on the power supply and your computer????
    the
    POST
    Any number of things: almost dead power supply, bad motherboard, bad
    processor, bad ram, just to name a few.
    Any
    Have you checked the ATX connector to ensure it is fully inserted in the
    motherboard socket? Is the ATX connector inserted with the correct
    orientation? (It should only fit one way but some people have managed to
    insert it backwards.)
    callsignviper
    The truth is out there. You just have to look in the right places and ask
    the right questions.
Homebuilt Hardware Power Supplies Power Systems
