Choosing mouse - optical, radio, Bluetooth?
G
Guest
Guest
Archived from groups: alt.comp.hardware,alt.comp.hardware.pc-homebuilt,uk.comp.homebuilt,alt.comp.hardware.homebuilt,microsoft.public.windowsxp.general (More info?)
I am still using a corded mouse (logitech wheelmouse).
I would like to get a better mouse which has at least as good
precision, responsiveness, accuracy, etc.
Would an optical mouse be better on all counts?
What about a cordless mouse. Are they poor performers? What about
a Bluetooth connection - is that good. Is it pricey.
Are there any web sites which discuss this. Google is no help to
me.
a
159
I have the logitech cordless desktop MX at home and a logitech cordless
keyboard & mouse (forgot model) in work. The MX has a charger / receiver.
The mouse lasts for about 3 days from a charge.
The mouse in work takes standard batteries. I have had it for about 5 months
and never needed to change the batteries (rollerball)
A few points to bear in mind:
- optical mice will drain batteries quicker
- dont go for a cheap brand ( i had a a4 tech keyboard & mouse, ended up
binnign it it was so bad)
"E2E t-bot BT" <English-to-English.translator.bot@Babel.Fish> wrote in
message news:94C6825DEB901K187D@64.62.191.98...
> me.
G
Guest
Guest
On Fri, 09 Apr 2004 12:48:56 +0100, "E2E t-bot BT"
Probably.
IMO, in most cases, wireless serves no purpose.
>me.
G
Guest
Guest
> me.
I use a Microsoft Wheel Mouse Optical (it's a wired version - about £15 on
Amazon.co.uk). Find it excellent, and the best mouse I've ever used, and
that's saying something as I've got through quite a few over the years.
Movement is good and it seems very responsive. Doesn't suffer from the
clunky feel that a ball based mouse has - it just glides when you move it.
Also the scroll wheel (on mine) is nice and free with a slight bit of a
click as you move it, where as some other models have a much stiffer scroll
wheel which I really don't like. I Spent about 30 minutes in my local PC
World trying out the button presses/wheel scrolling of their mice before
going back home to order one ;-)
Wouldn't go anywhere near a wireless mouse personally, as the two I've had
ate batteries faster than a mouse eats cheese/chocolate... as my PC is on 24
hours a day it's not hard for it to flatten (not fully flat, but beyond
being any use in the mouse) a set of decent batteries within a week or so!
You'll also find that as the batteries get flatter the responsiveness of the
movement goes way downhill, and it's as if you are using a mouse with a
highly gunked up ball/rollers, back to front, with your wrong hand, whilst
using it on your knee... keep far far away (although I know of a few people
who reckon they're great)
Simon
G
Guest
Guest
>> me.
> £15 on Amazon.co.uk). Find it excellent, and the best mouse I've ever
> used, and that's saying something as I've got through quite a few
> over the years.
> move it. Also the scroll wheel (on mine) is nice and free with a
> slight bit of a click as you move it, where as some other models have
> a much stiffer scroll wheel which I really don't like. I Spent about
> 30 minutes in my local PC World trying out the button presses/wheel
> scrolling of their mice before going back home to order one ;-)
> I've had ate batteries faster than a mouse eats cheese/chocolate...
> as my PC is on 24 hours a day it's not hard for it to flatten (not
> fully flat, but beyond being any use in the mouse) a set of decent
> batteries within a week or so! You'll also find that as the batteries
> get flatter the responsiveness of the movement goes way downhill, and
> it's as if you are using a mouse with a highly gunked up
> ball/rollers, back to front, with your wrong hand, whilst using it on
> your knee... keep far far away (although I know of a few people who
> Simon
I use wireless mouses exclusively, but your comments are correct. An
USB optical mouse will give better performance and control than a
wireless mouse and wireless do eat batteries. I have gotten accustomed
to the idiosyncrasies of the mouse with the trade-off that I can mouse
from nearly anywhere and there is no cable.
Q
G
Guest
Guest
It's very much down to personal preference. If find ball mice feel
more positive, probably because they make physical contact with the
mousing surface, offer some resistance and are generally heavier.
Optical mice can be more accurate but can feel less positive and,
despite working on a wider variety of surfaces, can get "confused" by
variations in reflectivity caused by colour changes etc.
The design of the mouse can make a great deal of difference too; you
find some mice more comfortable that others.
If you're thinking spending a reasonable about of money on a good
quality mouse I'd suggest trying it out first. Retail outlets such a
PC World are ideal as they often have lots of display models
side-by-side.
A good cordless mouse will perform as well as a wired one. The
benefit of optical cordless mice is the batteries add weight and, in
my opinion, make it feel more positive in use. The downside is the
batteries don't tend to last long in cordless optical mice so you'll
probably want to add the price of two sets of rechargeables and a
charger to the purchase cost.
Most of the BlueTooth sets offer little benefit over convention
wireless RF except range; RF tends to be limited to distances of
around 6ft between device and receiver where BT is around 30ft.
Driver support isn't as good as many BT devices require loading of a
BlueTooth stack before they will work; this means they only work
within a few supported operating systems. Unless you have a
particular requirement to operate the mice more than 6ft from the PC
I'd stick with conventional wireless equipment.
One exception to both rules is the Logitech wireless mice. Their more
recent models are supplied with rechargeable batteries and a base
station which recharges the mouse when not in use. Their BT
implementation is overlaid over their wireless technology and work in
every situation where their standard wireless or, for that matter, a
wired product would.
>iv< Paul >iv<
G
Guest
Guest
From my personal experience, I would prefer corded optical mouse.
I have been using my Logitech one for 3 years, still working fine for me.
Also, you don't need to worry about battery or any change in physical
contact of the mouse ball at all!
No problem in sensitivity for general use.
G
Guest
Guest
i used to use an infrared microsoft 5 button wireless mouse thing, and the
batteries needed to be replaced every 4 weeks
did get annoying though i must say!
my friends blue tooth on the otherhand... been about 2 or 3 months since he
last replaced the batteries!
battery life does depend quite heavily on the brand used.
blue tooth seems the way to go... but i only have experience with these two
mice!
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Microsoft's Bluetooth mouse is a "piece of **;$%^". It "goes to sleep"
everytime you stop moving for a few seconds. You have to click it to wake
it up. I used it for a few days and threw it in a drawer where it remains.
I will sell it cheap,
G
Guest
Guest
imho if your using the mouse with games dont go for cordless versions it
will drain the batteries a whole lot faster if your using cordless only for
graphic and other uses then by all means go for the cordless if you want to
i have a cordless versions both wheel and optical and still get by at least
2-3 months without needing to replace the batteries but get constantly stuck
inbetween games when the batteries run out at the vital moment. soon to be
replace my mouse with a wired version so i dont get caught like this again
"Louie" <popo@google.com> wrote in message
news:XUAdc.48464$_E.31658@newssvr25.news.prodigy.com...
G
Guest
Guest
I have a Microsoft wireless keyboard and mouse combo. However, I am still
using a wireless optical mouse made by Chic, which comes with a
re-chargeable "holster". An overnight charge is sufficient for the mouse to
last the next day. However, I have managed to wear away the silver paint in
two places through usage, so it is looking a bit tatty. :)
I have ordered a Logitech diNovo Media desktop combo as a replacement ( and
an Easter present to myself). :)
Doug Ramage
G
Guest
Guest
> me.
I like my logitech cordless optical mouse and keyboard combo. The newer
version of it, where the receiver acts as a battery recharger when not
in use, is even better (batteries run down in the mouse fairly quickly,
in my experience).
spammage trappage: replace fishies_ with yahoo
eLJay
On Fri, 09 Apr 2004 20:01:07 +0800, sooky grumper
>> me.
>in my experience).
Exactly my thoughts. Love mine, but I'll be selling my combo to get
the MX because of the charger.
G
Guest
Guest
> correct. An USB optical mouse will give better performance
> and control than a wireless mouse and wireless do eat
> batteries. I have gotten accustomed to the idiosyncrasies of
> the mouse with the trade-off that I can mouse from nearly
Is a USB port a better way to connect a mouse than PS/2 port?
G
Guest
Guest
I am using a Logitech MX700 cordless optical mouse. I have been using it
for over 6 months with NO problems. I'm using the PS/2 interface.
G
Guest
Guest
IMO, no. It's worse.
G
Guest
Guest
In terms of performance there's probably nothing of note in it, but
USB has the multi-purpose thing going for it.
Tim
Love is a travelator.
G
Guest
Guest
My MX700 came with NiMH batteries, and the charger is built into
the receiver/cradle. Simply insert the mouse into the cradle while
you sleep.
G
Guest
Guest
In article <os4e70h7cjo2dmfcdvap0jh9j1j1kh6q9n@4ax.com>, Tim Auton
<tim.auton@uton.[groupSexWithoutTheY]> writes
Disagree. I've used both and ps/2 is far, far superior. It just
registers your mouse movements with far more accuracy. Went from a £17
USB mouse to ps/2 for less than a fiver 6 months ago and have not gone
back.
Peter Ives
Remove ALL_STRESS only before sending me an email
G
Guest
Guest
"Peter Ives" <pete@pgives.ALL_STRESSfreeserve.co.uk> wrote in message
news:Mxc4EHASI0dAFwQk@pgives.ALL_STRESSfreeserve.co.uk...
> back.
But that's a different mouse, so there's no way of knowing whether the
difference was down to the mouse itself or the interface.
I have a Microsoft optical mouse (five button one, no idea what model),
which can be used either via USB or PS/2 (with an adapter). Initially I used
it on PS/2, but I couldn't tell the difference when I switched to USB a year
or so ago.
Alex
G
Guest
Guest
In article <c57hs0$2otro2$1@ID-149533.news.uni-berlin.de>, Alex Fraser
<me@privacy.net> writes
>message
>£17
>> back.
>or so ago.
Yes, but as far as I've read, the sampling frequency for ps/2 can go as
high as 200Hz compared to a mere 125Hz for USB allowing for more
precision, regardless of the quality of the mouse.
Peter Ives
G
Guest
Guest
"Figurt" <no.one@microsoft.com> wrote in message
news:c56jfb$2olo5e$1@ID-182387.news.uni-berlin.de...
he
two
> mice!
I use logitech cordless desktop, I have tried all logitech cordless models.
Liked them all, No real problems with the keyboard but as a games player I
note the mouse does run out fairly quickly, I replace the keyboard batteries
about every 5-6 months. When I am home I can run the mouse out in two weeks
easily.
But excellent combo, and a couple of AA batteries every two weeks isnt so
bad.
Try not to crosspost, it just pisses people off.
regards
Freddie
G
Guest
Guest
I use a MS Wireless InteliMouse Explorer 2.0 ... wouldn't trade it for
anything! The batteries add just the right amount of heft missing from many
optical mice, but i've grown use to the lighter feel of optical mice anyway.
I've never had ANY surface related issues with any optical mouse, ive used
on white formica, woodgrain formica, blue jeans, slacks, t'shirts, and when
the cat didn't want to get down... cat fur! they work on every surface i've
tried so far! Some wireless mice now are rechargable, but frankly i prefer
the battery kind, rechargables are known to run out of juice when you need
the mouse the most, and its a pain to have to wait 45mins+ to get enough
charge back on to function well, wheras I can throw in 2 spare AA batteries
in seconds and be on my way , and getting a massive stick of bats at costco
isn't all that expensive(i have half a stick of bats sitting in desk drawer
to have handy for the mouse), Ive run 2 months now without needing to
replace! Bluetooth does little more than give you more range, who cares
about bandwidth of a wireless connection when its just a friggen mouse, not
much data to tx, much less rx! I'm fine with my setup, the USB powered
"base" sits out of the way behind my monitor, and i can still use the mouse
from almost across the room, not that i need to, 99.9999 percent of the time
it sits in its usual place right next to the keyboard on the desk, but i
don't have to worry about its cables getting in the way (like they do on my
other desktop), and on a cramped desk its nice to be able to work the mouse
from wherever there is room instead of wherever the cable lets me go (even
if it meens the knee of my pants!) Bluetooth will add considerably to a
mouse, and like i said all it does is provide more range, perhaps it may add
some security, but on a mouse there isn't much that can be listened to, just
movements and clicks, listener has no idea what is being moused and clicked
so i'm not worried about it. Now for keyboards i will always be wired,
simply for security, sure someone can install a keylogger onto my system,
but firewalling and good spyware antivirus go a long way to prevent that,
but NOBODY can sit outside with a reciever and pick up what i'm typing cus
it ain't broadcast wirelessly! IF i had to go wireless for kbd it would be
bluetooth, and even then i would want the best encryption possible! An
optical mouse is good for price, and IMO not much else. They work great on
semisoft surfaces, usually poorly on hard surfaces, and surfaces need to be
flat as a general rule (usually not an issue.) DOWNSIDE is a major one for
me, and is the reason i left the balled mouse behind, AS A BALL MOUSE AGES
IT WILL NOT WORK RIGHT! And they do tend to age quickly! ANY dust ona
surface starts to build up on the rollers and before you know it the mouse
starts to "hang" or "skip" across the screen in one or both dimensions, you
can start to feel "bumps" in the movement. Sure you can clean it out, and
its not that hard to do, but ive found no matter how clean you make a dirty
mouse, it will never work like it did when new. Wheras opticals don't have
any moving pieces to get gummed up, and ive never had an issue with the
sensor not being able to see the surface, tho I imagine with LOTS of use it
would be wise to gently clean it (Have an optical mouse that ran for 2 years
on my machine, and has now run 2 more years when i gave that system to my
grandmother, both of us use(d) the computer more than 3 hours a day, never
needed cleaning!)
Gotta say that the wheelmouse is the way to go, especially if you are used
to it. If you go to a mouse without you will find yourself trying to scroll
a page without realizing you don't have the wheel anymore, you never know
how much you miss it. Some wheelmice can now tilt to scroll horizontally,
but i have yet to see a SMOOTH implementation of this idea, usually tilts to
click instead of being an axis like a good wheel behaves.
Like other posters have stated try out several, not just in the store, but
try and find someone that actually has a working mouse you can use (look
around the demo machines in your local computer megastore, chances are you
will find a decent variaty of mice to try out), but i think there is
something to be said for removing mechanical components from the mouse and
going to optical technolegy, Tend to get much more precise mouse movement,
and just like a ball mouse you can tell the OS how fast you want to dictate
mouse movement/acceleration.
Just my $0.04
> me.
G
Guest
Guest
news:$Rr08CAM60dAFwVX@pgives.ALL_STRESSfreeserve.co.uk...
> >used it on PS/2, but I couldn't tell the difference when I switched to
> >USB a year or so ago.
I'm not aware of any reason that a mouse connected via USB would be limited
to 125Hz sampling. What I do know about USB leads me to think that this is
unlikely (1kHz is much more likely), although USB need not be the limiting
factor. That said, the mouse position reported by Windows on this system
(with the mouse attached by USB) appears to change at (up to) 125Hz
The obvious related question is whether or not there is anything to be
gained by sampling at 200Hz. I think this is debatable, and the benefit
marginal at best. At 200Hz, there is a 2.5ms average and 5ms worst case
delay between moving the mouse and that movement registering. At "a mere
125Hz", these figures increase to 4ms and 8ms respectively. These seem
rather small periods of time in the context of human perception.
Alex
G
Guest
Guest
>me.
Optical is FAR superior to ball. There's no excuse not to buy a $15 MS
optical mouse now.
PS2 is slightly superior to USB at the moment.
Corded is slightly superior to cordless at the moment.
Perhaps there will soon be USB2 mice and all this will change.
Bob
Remove "kins" from address to reply.
