ATX Mainboard using an Mini-ITX Power-supplay
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi,
I have an AMD K6/2 Mainboard and try to connect it to an Mini-ITX Power
Supply having 150W
When I start the Computer it powers up but turns off 3 sec after start.
Can someone tell me why? Or is it not possible to connect the ITX
Power-supplay to an normal ATX Mainboard.
Thanks
Steve
5 answers Last reply
More about mainboard mini power supplay
  1. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    On Thu, 15 Apr 2004 23:14:19 +0200, Steve-Kai Vyska <steve@vyska.de>
    wrote:
    >Hi,
    >Supply having 150W
    >Thanks
    >Steve
    It sounds like the problem isn't necessarily that it's a mini-ITX supply
    but that, that particular power supply is insufficient capacity (or
    failing) for the system attached. If you have multiple hard drives or
    anything but a low-end video card in use you might try reducing the load,
    unplugging drives or swapping in a low-powered video card.
  2. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    > PSU overload protection maybe.
    And this means what?
    Steve
  3. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    When the power drain reaches a critical stage, the psu discconnects output
    to keep from overloading the circuits in itself and blowing up some
    components.
    Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
    http://mysite.verizon.net/res0exft/cpu.htm
  4. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    Hi
    > components.
    ah OK i see. But is it normally possible to use an Mini-ITX Power Supplay
    with an K6/2 Mainboard?
    Steve
  5. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    On Fri, 16 Apr 2004 13:02:46 +0200, Steve-Kai Vyska wrote:
    > Hi
    >> components.
    I have no clue. 150w sounds too small to me though.
Homebuilt Connection Power ATX Systems
