Archived from groups: alt.comp.hardware.homebuilt (
More info?)
"Ted Williamson" <TW@netSPAM.net> wrote in message
news:2rghc.83$G76.3352@news20.bellglobal.com...
> "Davolt" <DVC@telecom.SPAMNET> wrote in message
> news:nZfhc.81$G76.3227@news20.bellglobal.com...
> > I used the 10-pin (which fits and seems to be wired correctly) and
tried
> > individual wires with the same result: switched left and right on front
> > panel. I even switched around left and right (on the individual wires
> > method) ad while the front was OK, the back was switched. I'm going to
> try
> > the individual wire thing again and see what happens. Thanks for your
> > response.
> > Ted
> > "Russell" <rsullivan@tastycomputersdotcom_replacedotwith"."> wrote in
> > message news:qPfhc.25622$hw5.40635@attbi_s53...
> > > Antec's manual had a misprint regarding the audio pinouts. From Antec
> > > Sonata FAQ:
> > > Question: The audio wiring harness in my Sonata does not match the
> > > description in the manual. How should I connect it?
> > > Answer: Please follow these directions to make your Audio Connection.
> > > There is an Intel standard 10-pin connector (with also 7 individual
> wires
> > > with individual connectors) attached to a gray wire leading from the
> front
> > > panel speaker and microphone connection. If your motherboard supports
> > > Intel's standard onboard audio connector, you can plug the 10-pin
> > connector
> > > directly onto the board. For non-Intel standard audio connections, you
> > need
> > > to plug the 7 individual connectors into the motherboard.
> > > Instructions for non-standard audio connections.
> > > 1. Locate the internal audio connectors from your motherboard or sound
> > card.
> > > 2. Consult your motherboard or sound card manual for the pin-out
> > positions.
> > > 3. Microphone Power Pin: Connect the MIC connector to this pin.
> > > 4. Microphone Input Pin: Connect the MIC-BIAS connector to this pin.
> > > 5. Ground Pin: Connect the AUD GND connector to this pin.
> > > 6. Front Right Speaker Out Pin: Connect the FPOUT-R connector to this
> pin.
> > > 7. Front Left Speaker Out Pin: Connect the FPOUT-L connector to this
> pin.
> > > 8. Rear Right Speaker Out Pin: Connect the RET-R connector to this
pin.
> > > 9. Rear Left Speaker Out Pin: Connect RET-L connector to this pin.
> > > Note: Your motherboard may not support rear speakers output. In this
> case
> > > you do not need to connect RET-R and RET-L.
> > > Russell
http://tastycomputers.com
> > > news:_Hehc.78$G76.3384@news20.bellglobal.com...
> > > > I attached the front panel audio connector on my Antec Sonata using
> the
> > > > standard 10-pin Intel connector on my Asus P4P800 motherboard. When
I
> > plug
> > > > in a set of speakers or headphones to the front audio inputs, and I
> > switch
> > > > the audio to the left and right channel, it goes the opposite way.
> > > > When I have the speakers/phones hooked up to the REAR motherboard
> audio
> > > > connector everything is fine. Left is left and right is right.
> > > > I have tried pulling the 10 pin connector and installing each pin
> > > > individually. Same thing. I switched the left to the right
connector
> > and
> > > > the right to the left and the front panel worked fine, left was
left
> > and
> > > > right was right. I thought that was the solution but then the back
> panel
> > > > audio was switched around (left was right and right was left). I
> didn't
> > > know
> > > > that front and back panel audio were connected somehow. When I pull
> the
> > > > front panel audio connector out altogether I get no sound at all
from
> > the
> > > > REAR panel audio.
> > > > I am using the Asus software driver for their on-board audio and it
is
> > > > loaded correctly as far as I know. This is a real hair puller but
I'm
> > > > starting to think that the front panel is mis-wired at the
hdphon/spkr
> > > > connection itself and a properly wired connector would solve the
> > > problem.
> > > > Anyone have any idea what the problem could be?
> > > > Thanks, Ted
> sorry the last was from me on another's machine. wonder if it's the
software
> that might be switching the channels...
> Ted
I think I solved this. Instead of using the supplied 10-pin I took the 7
separate pins and hooked up both the back and front panel leads to the
opposite channel on the motherboard. So, back-left wire was attached to the
back-RIGHT mb pin, back-right wire to back-LEFT mb pin, front-right wire
went to front-LEFT mb pin and front-left wire went to front-RIGHT mb pin.
Now when you move the balance button left and right the sound moves to the
left and right properly both at the front panel and back panel. I have
verified that each channel is playing properly compared to my stereo cd
player.
The only thing I can think is that either the wires to connect to the
motherboard were mislabeled (unlikely) or (more likely) that the front
panel was wired exactly opposite as to how it should have been. Of course
it's also possible that, being an idiot, I missed something critical.
Anyway, it all works properly now so I will leave well enough alone.
