Can I use a sodium-cooling system for my PC?
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Because water-cooling does not work anymore and I think a
sodium-cooling system could be great for my 1.21 Terahertz machine and
the fusion power supply.
G
Guest
Guest
lord_melton@yahoo.com.ar (Carl Dau) wrote in message news:<15f2f483.0404202012.6ea72d63@posting.google.com>...
>machine and the fusion power supply.
Why not cool with the liquid helium from the superconducting coils of
your fusion generator?
G
Guest
Guest
"R. Anton Rave" <rantonrave@mail.com> wrote...
Maybe he's using room-temp superconductors...
Besides, escaping helium makes him tawk funny...
G
Guest
Guest
"John R Weiss" <jrweiss98155@.comNOSPAMcast.net> wrote in message
news:93vlc.22199$Ik.1599601@attbi_s53...
What you really want is "NaK" a mixture of sodium and potassium. It's a
liquid at room temperatures and above. But if it comes in contact with
water, it will burn explosively. The main advantage of NaK is its very high
thermal capacity -- a small volume can carry a lot of heat. However, plain
old water is just as good in any situation that you and your computer will
be involved in.
G
Guest
Guest
"William W. Plummer" <William.PlummerXNOSPAMX@alum.mit.edu> wrote...
high
plain
> be involved in.
Good point! NaK may even assist the CPU or the IP stack in servicing "Ack -
Nak" requests!
OTOH, Heavy Water may serve dual purpose as fuel and coolant, depending on
where it's routed...
