G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt (More info?)
Hi,
This question began with my attempts to find out why the CPU fan in my new
homebuilt PC was rotating so fast (5000+ RPM) and, as a result, causing so
much noise. I have one of the newish Intel P4 3E (Prescott/90nm)
processors - the core temperature of which seems to vary between 60 and 65
Celsius (with the Intel supplied heatsink/fan). Initially assuming that the
reason for the high fan speed was the high CPU temperature, I emailed Intel
product support who claimed that the cause was probably a failure to
maintain the internal chassis temperature at or below 38 Celcius (and that
this *chassis temperature* was what the CPU fan was responding to).
As part of this ongoing investigation, I've noticed that the case of my
power supply (an Antec TruePower 430) gets very warm - between 43 and 50
Celsius (depending on load). I can imagine that a large block of metal
emanating heat at 50 degress might make it difficult to maintain an internal
temperature of 38 Celsius! But... does this indicate a fault with the PSU?
What should the approxiate temperature be? (For instance, this review
http://www.anandtech.com/showdoc.html?i=1774&p=8 at AnandTech measures the
temperature *inside* the unit after 30 minutes at 33.7C)
As a comparison, I have another computer with a lower spec Antec TruePower
380 PSU. The temperature of its case holds rock steady at about 40C
irrespective of usage or apparent load - this is in contrast to mine which
fluctuates without really stabilising (at about 10 degrees higher).
It seems to me that I am rather stuck in a cycle between various
manufacturers/vendors claiming that there equipment is not to blame and I
definitely need some independent advice. The actual cooling system is two
120mm Antec case fans (one intake, one exhaust) in an Antec Performance One
P160 aluminium chassis. There are also the usual number of other fans in the
system - on the graphics card (ATI Radeon 9800 Pro) and North Bridge
(Gigabyte GA-8KNXP Rev 2.0 motherboard) etc.
-dan
Hi,
-dan
