Power Supply recomendation?
Ben
657
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hello,
What power supply would you recommend for the following set-up
AMD Athlon 3000+
Abit NF7
512 ddr ram
cdrom/and or dvdrom
floppy
I dont want anything fancy and expensive but something reliable and powerful
enough
Thanks
Charles
341
If you are going to use a Readeon 9800 or a high-end Video Card, you
may need around a 400 watt power supply. With a Nvidia 6800 you may
need a 450-500 watt power supply. anything less than a Radeon 9800
and you might get by with a 300-350 watt power supply. I prefer Antec
Power supplies.
G
Guest
Guest
> powerful enough
http://www.newegg.com/app/viewProductDesc.asp?description=17-103-481&depa=
Mac Cool
G
Guest
Guest
On Sun, 06 Jun 2004 22:08:39 GMT, "Ben" <ben@ben.com> wrote:
>Hello,
>AMD Athlon 3000+
>Abit NF7
>512 ddr ram
>cdrom/and or dvdrom
>floppy
>enough
You don't mention the number of hard drives or video card. Those two
components largely determine if a larger PSU is needed.
My first picks, given lack of above info, would be a Sparkle or Fortron
400W or Antec Truepower 420-430W.
G
Guest
Guest
>Hello,
>AMD Athlon 3000+
>Abit NF7
>512 ddr ram
>cdrom/and or dvdrom
>floppy
>enough
>Thanks
Thermaltake PurePower 420w
http://shop.store.yahoo.com/directron/w0009.html
regards
Dud
Attempting to debate with a person who has abandoned reason
is like giving medicine to the dead. - Thomas Paine
Ben
657
I will have 2 hard drives (maxtor 80 gig )
and my video card will be CHAINTECH nVIDIA GeForce FX5200 Video Card, 128MB
DDR, 64-bit, DVI/TV-Out, 8X AGP, Model "A-FX20" -RETAIL
which is about $60, not the most fancy one I guess
I was looking at Enlight ATX 420W P4 Power Supply, Model
"EN-8420934" -RETAIL
Is anyone familiar with Enlight power supplies?
Are they reliable?
Thanks again
G
Guest
Guest
I just wondered if anyone has tried out a Macron MT-400? I have been using
one now for about 2 yrs. My mobo bombed the other day though.
"Ben" <ben@ben.com> wrote in message
news:HBMwc.84632$oQ6.30462@twister.rdc-kc.rr.com...
> Hello,
> AMD Athlon 3000+
> Abit NF7
> 512 ddr ram
> cdrom/and or dvdrom
> floppy
powerful
> enough
> Thanks
G
Guest
Guest
On Sun, 06 Jun 2004 22:08:39 +0000, Ben wrote:
> Hello,
> AMD Athlon 3000+
> Abit NF7
> 512 ddr ram
> cdrom/and or dvdrom
> floppy
> enough
I've tested these three with a Jetway S755MAX MB, 3000+, 2 HD, 2 CDR's,
215meg, GF3.
Lead Power 500ATX $12
Lead Power 600ATX $24
Power Magic 550 $15 (shipped)
Any 500W or higher should work. Wouldn't buy anything less than 500W.
Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
http://mysite.verizon.net/res0exft/cpu.htm
G
Guest
Guest
On Mon, 07 Jun 2004 15:53:54 GMT, Wes Newell <w.newell@TAKEOUTverizon.net>
Use any of the above if you want to risk frying components, supporting
fraud, and ending up with a power supply that's worse than most name-brand
350W units.
G
Guest
Guest
>Are they reliable?
>Thanks again
The components you list should run from many good 300W PSU but preferribly
at least 350W, will give more margin and room for later expansion. 420W is
even better.
Enlight makes decent PSU, at least in the >= 340W models. They're the
same internally as a Chieftec or Thermaltake. My primary concern about
their PSU are that they use only median-quality sleeve bearing fans. Come
to think of it they may be one-ball & one-sleeve (per same fan), yet still
might only be labeled as "ball bearing". If there's anyplace in a system
that I strongly prefer top name-brand dual ball-bearing fans, it's the
power supply exhaust... not so important for the PSU intake fan, it isn't
subject to as much heat. Even so, the fan they use isn't so bad as many,
it may last for at least a couple years but would most likley be the
primary failure-point. IIRC, the Enlight 420W I have in a system here had
a Nidec Beta SL fan installed on the rear.
G
Guest
Guest
What power supply should be used in his situation? Mine will be similar as
I'm going with an Abit NF-7,(2) PC2100 DDR DIMM, (2) 40 Gig HDD's, XP2000
CPU, Retail AMD CPU 4800RPM fan, CDROM 50X, Floppy Dr., 6.96 Watts Chassis
Fan, AGP VGA ATI 7000 Video board + modem, sound board.
"kony" <spam@spam.com> wrote in message
news:qo69c0119fa56n8fvnsd720j13lkfeb85m@4ax.com...
> 350W units.
G
Guest
Guest
Antec Truepower 430W (~$60) should be more than sufficient. They also
have a True Power 480W (~$75) and True Power 550W (~$95)
IHMO, based on the modest requirements listed, 430W is more than
sufficient. But for future upgradability and if you don't want to
worry about undersupply, than you can get 480W or even 550W version.
However, the latter is a bit overkill.
"Doug" <fabien@toast.net> wrote in message news:<b59cbea8e869410670413fdb692bec64@news.teranews.com>...
> > 350W units.
G
Guest
Guest
> 350W units.
Just one question. Which of these PSU's did you test? I tested all of
them, which you just happen to leave out of the reply. And if you haven't
tested them, why are you even commenting? And to suggest supporting fraud
is just ridiculous. That's like saying someone that you think had gotten
some fake currency supports counterfeiting. You're more than welcome to
your opinion but your statements have no backing.
G
Guest
Guest
On Tue, 08 Jun 2004 05:10:03 GMT, Wes Newell <w.newell@TAKEOUTverizon.net>
>> 350W units.
Please publish reports of the tests.
So far you've only mentioned use powering parts that would run from a good
250W PSU.
>And if you haven't
Do I really need to fry my own systems to prove a pointor can't I just
observe it happening to others?
It's more like saying you knew the currency was fake, reprinted with ink
to be a higher value, and you encouraged others to "buy" this fake
currency. In this case we have your refusal to accept that these are
mislabeled, apparently, and your ignorance of the importance of safety
features. That mislabeling to sell them as higher wattage unit than they
are, is fraud. You suggest purchase of these mislabled units and sadly
enough, are clueless that a modern system as OP described doesn't need
"Any 500W or higher", rather that your mislabeled generics need to claim
such a high wattage to support the much lower wattage the system actually
needs, ulike most name-brands.
We have your one lone opinion countered by many others who've had to
replace such generics and too often the components powered by them. It
is not I that has need to prove anything, you have the majority against
you. Nowhere else would a consumer think it's a good deal to buy a
product claiming higher capacity than it actually is.
G
Guest
Guest
>>> 350W units.
How much or you willing to pay me for the work? Nothing? Then do your own
test.
> good 250W PSU.
AMD tech support recommends a minimum 450W for the A64. And I doubt if
you'll find a 250W with enough juice on the 12v rail. Maybe, if you spend
more than all 3 of the above together.
>>And if you haven't
IOW's, you have no knowledge of these units. Makes me wonder what your
motives are.
G
Guest
Guest
On Tue, 08 Jun 2004 07:55:16 GMT, Wes Newell <w.newell@TAKEOUTverizon.net>
>test.
How completely backwards you are.
I did not suggest use of those generics. I suggest proven viable
solutions. You have suggested something without even testing it.
>> good 250W PSU.
No, they don't as a system builder guideline. If you talked to a
cluesless level 1 tech, or simply someone who didn't want to bother
explaining power consumption, then perhaps they just took the quick
answer, suggest more power than needed.
AMD provides figures for consumption. Those are MAX values. Their
figures show that clearly, the A64 uses same or up to 50W more than the
Palominos did, yet they recommended 250-300W for Palominos, when they
were expected to be a larger burden on the PSU due to more imbalanced
power draw, most current from 3V + 5V rails.
In other words, any of their 300W PSU that were recommened for a Palomino
XP2000 would have an even larger margin for powering an A64 unless user
had an atypical number of hard drives, in which case I too recommend more
than 300W PSU. However, you are STILL CLUELESS. Your generic
recommendations DO NOT PROVIDE WATTAGE STAMPED ON LABEL.
You are suggesting purchase of power supplies that are worse than
name-brands with lower rated wattage, without testing them yourself... at
least you have made no mention of any testing, systems using them that
would not run from a decent, name-brand 300W PSU.
>>>And if you haven't
>motives are.
My motives are to point out that these amazing-bargain-cost power supplies
aren't a bargain. If you want to risk your own systems that is your
choice, but you suggest them as a high-wattage unit, which they are not.
If you mentioned them as "320W PSU that're fraudulently labled as 500W
with loose voltage shutoff to compensate for voltage drop" then I'd not
have written a word.
If you wrote that they're the "most" PSU one can buy for $15, then I'd
agree.
G
Guest
Guest
I've replaced noisy or dead 80mm fans in PSU's with new ones. Some PSU's
are hard to get at the fan, others are very easy.
Bob
Remove "kins" to reply by e-mail.
G
Guest
Guest
How stupid are you anyway. I said I tested them in my system in the
original message. Above, you even asked me to publish the report. You're
just another fudster. You have never had one of them to test yet you
spread fud around.
> supplies aren't a bargain. If you want to risk your own systems that is
> your choice, but you suggest them as a high-wattage unit, which they are
> not.
And you know this without ever even seeing one. Damn you're good, not!
You 've never seen one of the units or tested one by your own admission,
yet you know this for a fact. Are you known as the amazing pretzel?
> agree.
But I don't know if they are the best you can get for $15. So I wouldn't
say that. All I said is that they worked without a problem. That's it.
The person was on a budget and wanted something inexpensive and they will
work. Then you start in on your fudster tyraid. That's it for me. You can
try and spin this any way you want. Just sit on it first.
G
Guest
Guest
Kony is right. Just think about it.
"Wes Newell" <w.newell@TAKEOUTverizon.net> wrote in message
news:pan.2004.06.09.01.24.14.537937@TAKEOUTverizon.net...
at
> spread fud around.
> > not.
> > agree.
G
Guest
Guest
On Wed, 09 Jun 2004 01:19:22 GMT, Wes Newell <w.newell@TAKEOUTverizon.net>
>spread fud around.
Yes, you tested them in a system that doesn't actually need 500W, but then
promote them as suitable highe-wattage alternative. Truely you are
clueless if you can't fathom that the systems you mentioned don't need
anywhere near 500W.
>> not.
Please point out where I wrote that i've never seen one.
You jump to conclusions without reason, like your conclusion that an A64
is some kind of high-demand platform that needs a pseudo-500W power
supply, or that others would like for you to choose a power supply for
them without mentioning of the drawbacks.
So you don't have the facts about the power supply or this thread....
.... but you may have some strong drugs.
>> agree.
They may work without a problem but only until they fail, and providing
their true capacity is not exceeded or they're expected to have similar
serviceable lifespan. It's fine to make an informed choice for your own
needs but too often these are being mentioned as suitable for systems
needing higher wattage PSU. There is little to no savings in cost if a
fan fails, components are fried, or the system did actually need enough
amps on a particular rail that they'd use a "true" 400W+ PSU.
My initial claim was "Use any of the above if you want to risk frying
components, supporting fraud, and ending up with a power supply that's
worse than most name-brand 350W units."
These generics may have a "slightly" higher capacity than LP's lower
wattage units, but not more safety circuitry. Same failure of those will
potentially fry components.
They label them as 500-600W, when clearly they can't support that. What
would you call it when they deceptively label these units to be higher
wattage than they are, to cause a perception of higher sale value, if not
a fraud? When you suggest these units, you are supporting their choice to
relabel, since there are alternatives with more accurate labeled wattage.
Worse than most name-brand 350W units... open a couple up and compare
them... transformer size, inductors, capacitor size/ratings, safety
circuits, fans, etc, etc
Bottom line is that you're getting the bottom of the barrel parts that
when combined, allow a PSU to be built and cost only $15. I didn't even
mention the laborers who must be working for practically nothing making
these things.
G
Guest
Guest
Kony is quite right to demand numbers and facts. Your tests
without actual measurements - without the numbers - means that
even you don't know if your conclusions are valid. You, of
course, shorted out all the outputs from each supply, removed
the short circuit, and confirmed that did not damage
motherboard, etc?
Kony is right to ask for details of power supply tests. Too
often the most electrically ignorant make claims that a power
supply works - and are exposed only when others ask for
details.
Are you the classic computer assembler that has no
electrical knowledge but still recommends power supplies? I
hope not. But then those are the people who must then resort
to insult words such as 'fudster' - so they don't have to
provide technical answers. If not the classic and ignorant
computer assembler, then you can provide test details that
Kony requests. Only a fool would attach a power supply, see
computer work, and then declare the power supply fully
functional. But that is exactly what those technically naive
computer assemblers do to proclaim a power supply as OK.
Kony has asked for details that support your power supply
claim - as any good and technically informed poster would.
For others - be very suspicious of anyone who claims the $15
power supply is a better buy. Typically when challenged, they
must respond emotionally because their recommendation comes
with no basic electrical knowledge. Somehow they just know
the $15 supply is good enough and will therefore insult anyone
who questions them rather than provide technical reasoning.
>> yourself... at least you have made no mention of any testing,
>> systems using them that would not run from a decent, name-brand
>> 300W PSU.
> the original message. Above, you even asked me to publish the
> report. You're just another fudster. You have never had one of
> them to test yet you spread fud around.
>> power supplies aren't a bargain. If you want to risk your own
>> systems that is your choice, but you suggest them as a
> good, not!
>> as 500W with loose voltage shutoff to compensate for voltage
>> drop" then I'd not have written a word.
> admission, yet you know this for a fact. Are you known as the
> amazing pretzel?
>> then I'd agree.
> wouldn't say that. All I said is that they worked without a
> problem. That's it. The person was on a budget and wanted
> something inexpensive and they will work. Then you start in on
> your fudster tyraid. That's it for me. You can try and spin this
G
Guest
Guest
<snip>
What I meant to write was that I replaced PSU's original fan with the
Nidec, not that it came with the Nidec preinstalled at the factory.
G
Guest
Guest
On 7 Jun 2004 21:14:19 -0700, email_invalid@mail2world.com (Email
I've got a 550 and it's a decent, quiet psu for the price. I'd go 430
or 550 depending how many hard drives you expect to have. I'd skip the
480 for the price difference.
If price were no object, I'd get the top of the charts psu, but they
can get exponentially expensive.
G
Guest
Guest
On 10 Jun 2004 05:36:17 -0700, larrymoencurly@my-deja.com (larrymoencurly)
wrote:
>Anyone who makes a claim is responsible for backing it up, and you
The claimant should be taken at his word unless he has lied before or makes
incredible claims. If you doubt a claim, then test it yourself. It's a
slippery slope when everyone must start proving everything to everybody. Or
something like that. Nyuk nyuk nyuk!
>didn't simply say that those PSUs worked in your system but that any
>500W+ PSU should be fine. Considering that many cheap 500W+ PSUs look
>less substantial than many of the better 300W PSUs, I find it hard to
>believe that a 550W selling for
>$15 can be trusted when lots of power is needed, unless it was a
>surplus special.
You hit on a very important principle. Better power supplies have heavy
coils, lots of components and heat sinks stuffed inside. A good accurate
postal scale would probably be as good an indicator of quality and
performance as all the electrical test gear. :)
Bob
G
Guest
Guest
Wes Newell <w.newell@TAKEOUTverizon.net> wrote in message news:<pan.2004.06.10.19.28.06.691636@TAKEOUTverizon.net>...
> On Thu, 10 Jun 2004 05:36:17 -0700, larrymoencurly wrote:
> > Considering that many cheap 500W+ PSUs look less substantial
> > than many of the better 300W PSUs, I find it hard to believe
> > that a 550W selling for $15 can be trusted when lots of power
> > is needed, unless it was a surplus special.
> So now you want me to to provide data for all cheap power
> supplies. I wouldn't hold my breath.:)
> Now, since you say many cheap 500W PSU's are less substantial
> than many of the better 300W's, why don't you prvide the data
> to prove this. Rediculous as that sounds, it's exactly what
> was asked of me. So for get it.
Compare this: www.bit-tech.net/images/review/123/7.jpg
to this: http://terasan.okiraku-pc.net/dengen/no20/open.jpg
http://terasan.okiraku-pc.net/dengen/no20/up02.jpg
(lots of PSU internals pictured at
http://terasan.okiraku-pc.net/dengen/ )
If you didn't know anything else about either PSU, which one would you
think had the higher power rating? The first PSU is a 550W Q-tec
while the second is a 300W Powerman (Fortron-Source, also makes
Sparkle), and unless the Q-tec's transformer has higher capacity for
the same dimensions or is run at a higher frequency, how can it put
out more power than the Powerman's? Similarly, unless the Q-tec is
more efficient (fat chance), won't its heatsinks likely run hotter at
any given power level than the Powerman's? But most of all, why do
companies like PC Power & Cooling, Antec, and Fortron-Source use
bigger capacitors, heatsinks, and transformers if they're unnecessary,
especially when most customers don't care about the insides?
Except for an Enermax, all the PSU failures I've experienced have been
with cheapos. One didn't have good overload protection for the +3.3V
(almost identical to the one shown by PC Power & Cooling as an example
of a bad PSU), a low voltage capacitor in a Powmax failed (could have
been one of those made with faulty electrolyte), and a Deer shorted
several 16V capacitors, probably because it sent 50V spikes into them.
And that failed Enermax was badly made 250W without an anti-surge
thermistor.
