Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.hardware.homebuilt (More info?)
I have a Lian Li PC 60 all aluminum case. The system is an ECS K7S5A
with Athlon XP 1700+, 1GB DDR Kinston RAM (2x512k), 350W Enermax PS.
The drive cage is at the bottom of the case in the front. There are
two fans blowing in from the front of the case onto the drive cage.
The fans pull intake from vent holes on the front panel of the case.
There is an air filter between the vent holes and the fans.
I recently had a WD80GB drive lose the circuit board. I was able to
replace the board, extract data, etc. I'm am now ready to re-install
the drives. I had one WD800BB and two WD400BBs. During this process
I ended up with another WD800BB. I now have four drives. All four
drives (two WD800BBs and two WD400BBs) are 7200RM Ultra ATA 100.
I noticed that when I pulled the cage out originally it was pretty
warm and I'm wondering if that is what killed the circuit board on the
drive that died? Right now I have all four drives mounted in the cage
running on a piece of cardboard outside the case on the floor. The
side of the case is off. The drive cage gets pretty warm to the
touch. I'm kind of afraid to put the drive cage back into the case
and seal it up without knowing what to expect. Anyone had any
experience with this case and drive temperature? What is the best way
to load it up with drives?
TIA,
Paul
TIA,
Paul
