Opinion on Sound Cards?
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I'm building a media server to hook up to my home theater system. I have
two sound cards salvaged from old systems to choose from. One is a
Turtle Beach Santa Cruz, and the other is a SB Audigy.
Does anybody have a strong opinion on which one would be a better choice?
One factor might be that the system has a somewhat underpowered CPU - an
AMD Athlon 1.4. If either of these has a better engine, and can
accelerate decoding MP3s, that might be a factor.
Any and all opinions welcomed.
....I'm an air-conditioned gypsy...
- The Who
G
Guest
Guest
On Mon, 5 Jul 2004 15:52:33 +0000 (UTC),
Audigy is the better of the two, but an Athlon 1.4 is plenty
powerful for (any card), there should be no issue of whether one
has a more efficient engine, even a Celeron 800 should be
overkill, even if playing from DVD. Divx full-res decode might
benefit from 1.2 GHz+ though.
If you'll be using analog out, your subjective opinion (from
trying both) might be the best way to choose.
G
Guest
Guest
Using the Audigy will give you better sound quality and put less of a load
on the CPU.
DaveW
<EskWIRED@spamblock.panix.com> wrote in message
news:ccbtg1$s9j$1@reader2.panix.com...
> - The Who
G
Guest
Guest
> on the CPU.
Thanks. The Santa Cruz is older, but I liked it when I got it. So I
figured that it wouldn't hurt to ask.
- The Who
