G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hey all-
I'm running an AMD Athlon Thunderbird, which according to the specs is
1.33ghz with a 266mhz FSB on an ASUS a7n66-vm, which supports 200 and 266
mhz FSB's. Anyway, according to two diagnostic programs, the it's running at
1.33ghz like normal, but only 133mhz on the RAM. What's weird is:
..EVEREST Home Edition says that the CPU is running at 133 on the FSB.
..Belarc Advisor says the circuit board supports 133mhz.
..The ram itself is Elixir, and should run at 333mhz at most.
So what's the deal? I'm not sure if it's always been like this. There's
nothing in the BIOS to work with because OC'ing and other clock stuff is
disabled without doing some nice little modifcations to the board itself.
-Jon
Hey all-
-Jon
