Building new system
Last response: in Systems
Anonymous
Homebuilt system Expert
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Anyone:
I seem to have been forced into finally upgrading and building a new system
since my current one passed on.
My question is regarding motherboards and what I want to include. The old
system was a PIII 600 running on an ABIT BE-6II which had 4 IDE controllers
on the board allowing me to install a CD writer, DVD drive, Iomega Zip
drive, and of course my hard drive(s) which was a master/slave
configuration. 2-20 GB units.
The boards I'm looking at all simply have 2 IDE controllers. My question is
how can I install the same components to the new one? Do I have to sacrifice
the zip drive? I really like having that and want it incorporated in the new
box. Anyone with suggestions as to how I can accomplish that, please let me
know, ok?
I want to thank all who gave me advice regarding the death of my old system,
seems the Mobo fried and hence, the new unit.
The boards I'm looking into are:
PC Chips M848 with Anthlon XP3200
Asus P3B-F with the same XP3200
Any one know of a board that will accommodate the XP3200 yet still allow me
to install all the above named peripherals?
Thanks again,
Gerry Wolf
gwolf@wi.rr.com
More about : building system
Anonymous
Gerry Wolf wrote:
> Anyone:
Yes, well, the BE6II is based on the 440BX chipset which has a dual channel
UDMA33 IDE controller built in but they wanted RAID and UDMA66 capability
so they essentially built in an 'add-on card' with a highpoint controller
> know, ok?
Do what Abit did, except the 'normal' way: add in a PCI IDE controller card
with whatever features you want on it.
> Thanks again,
> Gerry Wolf
> gwolf@wi.rr.com
Anonymous
On Wed, 8 Sep 2004 20:43:11 -0500, "Gerry Wolf"
<gwolf@wi.rr.com> wrote:
>Anyone:
>know, ok?
This Asus P3B-F does not support XP3200, it's a socket 370
motherboard!
Frankly I'd buy a better motherboard with savings from
buying only the XP3000, if the system budget is fixed, but
it's your call.
Most of the modern Athlon boards integrate a serial ATA
controller as the 2nd controller (in addtion to the one
southbridge-integrated).j To get the PATA raid you want,
buy a PCI RAID card, preferribly ATA133 to provide native 48
bit LBA (large > 128GB size) support.
Anonymous
> motherboard!
As a matter of fact, the Asus P3B-F neither supports PC3200 RAM nor is
it a socket 370 motherboard. You are cordially invited to visit a
computer museum to find out that P3B-F is a Slot 1 (SECC or SECC2)
board for Pentium II and III (and corresponding Celeron) CPUs,
supporting PC100 (and, especially for overclocking) PC133 SDRAM RAM
modules.
Roy
This posting is provided "As Is" with no warranties and confers no rights.
Related ressources
Anonymous
> motherboard!
The P3B-F is a Slot 1 board supporting Pentium II and III (and
corresponding Celeron) CPUs - not Athlon XP processors.
Gerry Wolf might consider a board from the value line daughter of
Asustek, i.e. ASRock rather than PC CHips...
Roy
You could get a pci card that will give you more IDE channels. It is
inexpensive.
Go for the Asus motherboard.
Gerry Wolf wrote:
> Anyone:
> know, ok?
> Thanks again,
> Gerry Wolf
> gwolf@wi.rr.com
Anonymous
"Gerry Wolf" <gwolf@wi.rr.com> wrote in message
news:UwO%c.22281$nA6.14993@twister.rdc-kc.rr.com...
> Anyone:
> system
> controllers
> is
> sacrifice
> new
> me
> know, ok?
> system,
> me
> Thanks again,
> Gerry Wolf
> gwolf@wi.rr.com
jesus man, not pc chips!
Ask the community
