Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hello all.
I have a new computer, windows xp is the operating system and all the
drivers are loaded and its running fine.
So what is my problem?
When a USB device is connected and turned on it works OK. If the computer is
then rebooted it goes through start up and the windows xp logo appears, the
page then turns black and hangs it does not reach the welcome screen. If I
turn off the USB device or if I remove the USB lead the computer then
continues as if nothing had happened.
Anyone know what I can do to sort this problem out.
Thanks
Hello all.
Thanks
