Archived from groups: alt.comp.hardware,alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt (
More info?)
On Wed, 15 Sep 2004 22:20:15 -0400, "Eric Gross"
<ecg5@po.cwru.edu> wrote:
>If you're looking to do it a fairly cheap way, I'd go for a board with a VIA
>Apollo Pro 133A chipset. It supports the 133Mhz bus which your 1Ghz
>processor probably uses (assuming its not a celeron, which runs at 100Mhz).
>The only Intel-made chipsets for socket 370 systems that supports a 133Mhz
>bus and over 512MB of RAM uses RDRAM, which is a bit too pricey to think
>about for a large amount of RAM. If it is in fact a celeron, you may be able
>to get by with an Intel BX-based board (with either native FC-PGA support or
>with an small adapter). The BX chipset can accept more than 512MB of RAM,
>but it will only take the lower density chips so putting in 512MB modules
>becomes very pricey.
BX does not support 512MB modules, IIRC, 256MB per.
>The Apollo Pro 133a boards can take the 64x64 high-density PC133 modules
>that are much cheaper per MB than the normal lower-density ones. You can get
>512MB modules like this for around $30 each if you search pricewatch. You
>should be able to put 1GB easily in, maybe more. To get much more than that
>you'd probably need to step up to a more server-class board with a
>server-level chipset that takes registered RAM.
Apollo Pro 133A or 133T are good choices, the 133T if only
because it's the newer generation, best odds of most
refined/mature board and of supporting 48bit LBA. $30
pricewatch modules might be a problem though if trying to
max out the board, often when using more than 2 of the cheap
512MB modules I found that era of board to be instable,
unless higher-grade memory was used instead. That's not to
say that can't work, but if modules are bought from somplace
with poor return policy as often found on pricewatch, it
could be a real PITA to get modules that work OK alone,
replaced because they won't work with 2 or more identical
modules used. LOL, some of the companies on pricewatch
might send a 64MB dimm and still it's a PITA to get them to
just replace and send what was ordered or get a refund.
Another potential issue is that a few of the boards from
that era (actually more than just a few, many of them) had
the "potentially" defective capacitors in 'em, labeled as
Lelon, Luxon, Tayeh, Jackcon, I.Q, JPCON, Chhsi, et al.
