potential power supply problem?
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi,
I have a problem with a machine where I turn it on and nothing boots
and oddly enough, I don't get any beep codes.
Details:
power supply is atx 2.03
motherboard is ga-7vax (have already tried replacing the motherboard)
I have done the following:
Removed disks, ram, all cards, fans, and even the processor.
Shouldn't I receive a beep code or two for stripping everything off
the motherboard?
The only thing else I could think of was the power supply, but the
disks and fans (when connected) receive power. However, I don't know
enough about power supplies. Is it possible that part of the
motherboard isn't power? Or is power on a motherboard all or nothing?
Thanks in advance for any help or hints. I would really appreciate
just about anything at this point.
-Kevin
5 answers Last reply
More about potential power supply problem
  1. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    blocker1@chuey.net (Kevin Chu) wrote in message news:<c081de8a.0409192138.1938e942@posting.google.com>...
    > Hi,
    > Details:
    > the motherboard?
    > -Kevin
    I really don't know of any motherboard that would produce any beeps
    when the processor is not in there. Some BIOSs will have long steady
    beeps when the memory isn't in there. Some will power up and do
    nothing. If the fans are spinning and all your LEDs light up then
    most likely the PSU is still good. The BIOS chip could also be bad,
    but you have replaced the MB. I would check a couple of things:
    1. The CMOS jumper is not set to clear.
    2. The CPU fan is plugged into the CPUFAN1 slot.
    3. Try to test the RAM in another computer.
    4. Try to test the CPU in another computer.
    My guess is that either the CPU or RAM is either bad or seated
    incorrectly.
    -Jay
  2. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    Sounds like it may be a faulty power supply unit to me. I would recommend
    replacing it with a known working one. This would be the easiest test you
    could run.
    DaveW
    "Kevin Chu" <blocker1@chuey.net> wrote in message
    news:c081de8a.0409192138.1938e942@posting.google.com...
    > Hi,
    > Details:
    > the motherboard?
    > -Kevin
  3. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    jcousins@crtpr.com (Jay Cousins) wrote in message news:<59f788f4.0409200753.1a568158@posting.google.com>...
    > > Hi,
    > > Details:
    > > the motherboard?
    > > -Kevin
    The machine used to work and none of the motherboard settings have
    been changed, so I'm assuming all the settings on the motherboard are
    correct.
    Shouldn't I be able to eliminate the CPU and RAM from being the
    culprit because I removed them? Or is my assumption that the
    motherboard would beep if those two components were missing faulty?
    Thanks,
    Kevin
    > incorrectly.
    > -Jay
  4. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    > > Hi,
    > > Details:
    > > the motherboard?
    > > -Kevin
    correct.
    Thanks,
    Kevin
    > incorrectly.
    > -Jay
  5. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    news:c081de8a.0409270724.eec7471@posting.google.com...
    > > > Hi,
    > > > Details:
    > > > the motherboard?
    > > > -Kevin
    > correct.
    > Thanks,
    > Kevin
    > > incorrectly.
    > > -Jay
    I think if the bios has gone bad there are no beeps, Also...If the CPU has
    been removed it will not beep. also check to make sure your PC speaker is
    hooked up and nothing is wrong with the wires. That could be why it will
    not beep. If Only memory is bad or removed, it will give 3 long beeps. but
    I do not think anything happens with a dead CPU. If you have another CPU
    with the same Socket set you might want to try it in this one. BUT you risk
    damaging the other CPU if it was a problem with the motherboard. Be careful
    with that.
    Kevin
Homebuilt Power Supplies Motherboards Systems
