Archived from groups: alt.comp.hardware.homebuilt (
More info?)
On Wed, 22 Sep 2004 20:58:58 -0400, "Cheo Artesano"
<cheoartesano@hotmail.com> wrote:
>I have a P4C800 Dx with an AGP, Radeon All-IN-WONDER 9600 Vcard, WinXP, P4
>2.1gig and 512 RAM
>After I installed the system everything worked fine. A while back the
>picture of my monitor stopped using the full screen, after attempting to fix
>the problem with new drivers and checking the hardware, I re-formatted the
>PC, a Maxtor 80G which requires a DDO program to be fully recognized by XP,
>and installed everything anew.
No, your motherboard determines the hard drive size limit
(rather, it's bios does) and your motherboard does NOT need
a DD0 for an 80GB drive. IMHO, since you are wrestling with
this already, better to back up and figure out what's going
on with the hard drive (check bios settings and drive
jumpers) and get the drive properly working without the DDO.
>It was fine untill I started a game, Madden 2005, the screen windowed, not
>full screen, while the game was on. On exiting the game, the monitor was
>full again.
That sounds more like a game bug than anything else (or
driver problem, considering it's an ATI card).
>Well, today even the Windows XP desktop was smaller and everything is back
>to where I was.
Define "smaller" in this context.
Might it simply be set to a different refresh rate, or is
the actual resolution different?
See if the monitor is properly detected in Display
Properties and/or Device Manager... did you assign the
correct monitor INF file ("driver") for your monitor, or at
least chose Plug N Play? Did you previously boot system
with monitor turned off?
>Any help will be appreciated. Thanks!
>BTW, on startup, the screen was windowed up to the Win XP Welcome screen.
>The screen used to be full all the time, from the start.
Have you adjusted your monitor's on screen displays to try
to correct this previously, thus causing this "windowed"
appearance. "Windowed" could also mean different things,
since the OS is presumably windows, but a window to some
might mean a black border around the displayed image.
If all else fails, uninstall the video driver (Add/remove
programs), reboot, set to generic VGA video, then install
video driver... perhaps a different version this time, the
newest if you weren't previously using newest version...
which may also require newer version of DirectX, like 9b,
though now 9c is current, might as well use that if you have
it.
