G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc (More info?)
Shuttle AN35(N) Ultra
Win XP Home SP2
On Power Options Properties, Power Schemes, I have Monitor set to Never go
off.
I previously described the behavior of my newly acquired (but used) HP
A4033A Monitor. Specs:
http://www.griffintechnology.com/archive/monitors/Hewle12.html I didn't
figure out the problem, but the monitor is usable.
Anyway, after using it for a few days, I can describe its behavior somewhat
better.
When I shutdown and reboot using another monitor, a Compaq 171FS,
everything, including the monitor, works normally.
When I shutdown and reboot using the HP A4033A, the monitor Immediately goes
into Power Saving, and I can't get it out of it by turning the monitor
switch off and on. If, however, I'm up and running on the Compaq monitor and
then I switch monitors to the HP without turning off the system, then the HP
functions normally - at least until I try to reboot.
Anybody know what's up?
* Nehmo Sergheyev *
Win XP Home SP2
off.
better.
* Nehmo Sergheyev *
