Archived from groups: alt.comp.hardware.homebuilt (
More info?)
On Fri, 01 Oct 2004 16:45:58 +1000, Franc Zabkar
<fzabkar@optussnet.com.au> wrote:
>On Thu, 30 Sep 2004 22:41:28 +0100, "MJP" <mjpjunk32@hotmail.com> put
>finger to keyboard and composed:
>>"noway" <noway@noway.net> wrote in message
>>news:7YmdnbzYjLYTL8TcRVn-sg@adelphia.com...
>>> Hi, I want to set up seperate hard drives one with linux one with win (had
>>> no luck with partitions) what I thought would work would be to take both
>>> hard drives set them to master and have a switch which would turn the
>>power
>>> off of either one. ( simple two position switch. Using eide would this
>>> work?
>>How about a couple of hard disk caddies. Set both drives to master, set auto
>>detect in the BIOS. Put the disk that you want to boot from in the machine,
>>start machine. To change, power down replace disk power up
>Too frequent swapping will probably fatigue the connectors. IMO, CB's
>solution is the neatest, although I would prefer a DPDT switch. Having
>said that, I can't see why a single drive with separate partitions was
>unworkable.
I've been using caddies for some years now for my backups, and in
those years I've only had one caddy 'go suspect' on me - and these are
cheap plastic ones I got off ebay. The trick is to buy a couple of
spares of the same brand and just swap 'em out if there's a problem.
The external interface is a simple printer plug and socket - which is
sturdy enough.
Better quality caddies are available ( made from aluminium etc. )
Check the speed rating though - some of the older/cheaper type can't
handle ATA33/66/100 etc. The drives will still work, but at less than
optimum speed.
But how about a boot manager?
Using something like XOSL you can set each drive to boot on choice,
and it'll even allow you to boot from an extended partition or a slave
drive. Works for me!
There are plenty of pages out there on the web that will help you set
up multiple boot partitions using a boot manager.
Regards,
Stephen Howard - Woodwind repairs & period restorations
www.shwoodwind.co.uk
Emails to: showard{whoisat}shwoodwind{dot}co{dot}uk
