Archived from groups: alt.comp.hardware.homebuilt (
More info?)
none wrote:
> On Sat, 16 Oct 2004 23:29:02 -0500, David Maynard <dNOTmayn@ev1.net>
> wrote:
>>none wrote:
>>>On Sun, 10 Oct 2004 01:24:11 GMT, Larc <larc-news@jupiterlink.net>
>>>wrote:
>>>>On Sat, 9 Oct 2004 11:31:13 -0700, "Kent_Diego" <None@Nomicrosoft.com>
>>>>wrote:
>>>>| > I worked on my nephew's dinosaur the other day and he has this old Sony
>>>>| > monitor that has an individual control knob for each setting: contrast,
>>>>| > color, height, width, horizontal & vertical spacing, etc. It was so easy
>>>>| to
>>>>| > adjus, no on-screen menu to time-out, or scroll through, just direct
>>>>| control
>>>>| > by turning the right knob! I loved it, sure wish that modern monitors
>>>>| would
>>>>| > go back to this kind of control!
>>>>| Yes but it probably cost $700. Losing the knobs saves money. Remember when
>>>>| TV sets had a channel display? It's been a long time. The modern monitors
>>>>| ability to remember the settings for each resolution is a lot better then
>>>>| having to fiddle with knobs all the time.
>>>Are you trying to say that simple control pots are MORE expensive than
>>>complicated chip memory dependent controls?
>>>Sorry but you're incorrect, it actually costs MORE.
>>Nope. The microprocessor controls are not only better overall but less
>>expensive.
> You'll never convince me that they are cheaper than potentiometers.(I
> spent many years in the electronics service/repair business.)
It may be that no one can convince you but the fact of the matter is that
they are.
The microprocessor replaces a whole host of internal adjustment components,
greatly reducing assembly costs, and simplify the alignment process wile
improving it as well. The last step, to convert the front panel pots to
pushbuttons is done with a simple piece of laminated plastic, the membrane
switches, that come dern near free; not to mention simpler mounting and
less discrete wiring (assembly cost).
You're looking at the 'repair' cost of replacement thinking, boy, the 'one'
pot I imagine I would need, vs this microprocessor, is cheap but try
designing and manufacturing 'the whole thing'.
