G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Received my DVD writer today (NEC 3500) and I've run into a bit of a
problem with the installation.
On my PC I already have a normal DVD player. I installed the writer in
as master and set the DVD player as slave and connected them both to the
second IDE connector on the motherboard.
Now with this configuration my boot up slows down (takes far longer to
reach the Windows XP spash screen)
Also, only one drive is visible on Device Manager and My Computer.
I checked the bios and it finds both drives fine. Also it all works fine
if I connect either one on its own(windows also boots up faster)
Any ideas why I can't install both drives? I have a feeling it may be
that the Power supply may not be powerful enough. Could this be it or
some kind of settings problem
My system
Antec 380W TruPower
MSI K8N Neo Motherboard
AMD 64 3000+
2x512MB Crucial Ram
Sapphire 9800 Pro
Samsung DVD
NEC 3500 DVD-RW
My system
Antec 380W TruPower
AMD 64 3000+
2x512MB Crucial Ram
Sapphire 9800 Pro
Samsung DVD
NEC 3500 DVD-RW
