G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi Folks,
I've tried to Google on this problem, all to no avail. Apologies if this is in
a FAQ here (I looked for that too).
Home-built PC. Worked fine for a couple of years.
Recently we swapped the PC to another room (and now owned by another of my kids)
and a few weeks later we heard a "tick tick tick" sound of about a two or
three second interval.
My philosophy was to leave it until there was a "hard" failure of some sort, but
the new user kept complaining about sporadic reboots.
Eventually I opened the case and discovered the source of the sound - the internal
speaker. Since the rebooting was still sporadic, I vacuumed the innards,
removed and reseated the boards and put it all back together.
Same sound, same sporadic reboots.
A few days later the rebooting became a regular occurence - on a 3-minute cycle.
Since I tried everything else, and since I just remembered that another son
had a spare power supply for his machine, I swapped that.
Result: no ticking and no rebooting!
Well, that lasted for about 3 weeks. Now it won't boot at all.
We took the new PSU and installed it in another machine, with full success.
The symptoms of the present situation are that when I press the power button
I can see the CPU fan spin for 0.5second and then go still. Prod the power
button again to no effect. Switch the computer PSU off at the mains for a
few seconds, reapply power and it all repeats.
I'm guessing that the soft-power circuitry has caused the PSU to close down
very swiftly after power up.
My guess is that the failing old PSU has damaged the motherboard - but you
folks will probably know better.
Any suggestions welcomed; thanks in advance.
Mungo Henning
Hi Folks,
Mungo Henning
