No Audio In Available - solution needed...
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi,
Just to check if there is any solution to this situation.
I have a Shuttle with am FB61 Mainboard.
There is no free PCI slot, and the built in sound card does not have an
AUDIO-LINE IN as far as I can tell.
I need to connect a TV card (WinTV) with the LINE-IN and I do not want
to use an external sound card if I can help it.
I have one free AGP slot - perhaps there is a high end graphics card
that can also do sound...?
Any other tweaks I can do that might allow me to solve this?!
Any tips appreciated!
Johanna
3 answers Last reply
More about audio solution needed
  1. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    Johanna wrote:
    > Hi,
    > Johanna
    Use the CD audio connector.
  2. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    Howdy!
    "Johanna" <johanna@homechoice.co.uk> wrote in message
    news:419fc628@news1.homechoice.co.uk...
    > Hi,
    *blink* I'd hazard a guess that the connector between the LineOut
    (or Speakers) and the Mic In would be, as it's labeled, "Line In".
    And are you sure that's a Shuttle FB61 mainboard? It's not listed
    on their web site.
    > Johanna
    RwP
  3. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    On Sat, 20 Nov 2004 22:33:13 +0000, Johanna
    <johanna@homechoice.co.uk> wrote:
    >Hi,
    >Johanna
    While the following pic may not be of your (XPC?) it
    "appears" to be same motherboard from scant 'net evidence.
    Anyway the pic shows the line-in jack plainly for a
    microphone and line,
    http://www.firingsquad.com/media/hirez.asp?file=/hardware/shuttle_sb61g2_review/images/08.jpg
    Or on the front
    http://www.firingsquad.com/hardware/shuttle_sb61g2_review/images/09.jpg
    Perhaps the front-panel jacks have a proprietary header on
    the board? That'd be commonly how it's done, with a
    double-row of pins or something more proprietary.
    In the following picture it looks a lot like there are three
    audio cables just to the left of the heatsink, presumably
    leading to all three audio jacks.
    http://www.firingsquad.com/hardware/shuttle_sb61g2_review/images/16.jpg
    Here's another angle of that but it's a bit too blurry to
    make out the connector sockets.
    http://www.firingsquad.com/hardware/shuttle_sb61g2_review/images/19.jpg
    Or, is that not even similar to your motherboard? The pics
    came from a gallery here:
    http://www.firingsquad.com/media/article_image.asp?fs_article_id=1258&pic_id=01
    linked from this review:
    http://www.firingsquad.com/hardware/shuttle_sb61g2_review/default.asp
    When all else fails, check your manual.
Homebuilt Audio Sound Cards Systems
