First home-built PC
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Good Morning,
I recently bought a barebone pc fron an online retailer. To my surprise,
the PC came in parts so I had to put it together (first time). This is not
my first time working with PC. I got a Asus (A8V) mother board with a AMD
64 3400 CPU, 512 (ULTRA-400) memory, 120 GB hard drive, Chaintech G-Force
FX520 v-card and a 16X DVD burner all this in a SOYO case.
After putting about six hours working on the PC, the PC would not work. I
contacted the retailer and they sent me a mobo replacement (apparently the
Asus mobo was bad). I received an Abit AV8. I put the PC together again
and the same result. The P/S was checked and it works. I get power to the
motherboard, but nothing else happens (I know this, because the AV8 has two
LED, one that indicates power supply is connected to a power source, and the
other indicates the system power is on). The second LED does not come on.
The motherboard indicates that does not support 3.3V AGP cards. To use only
1.5V or 0.8V AGP cards.
How can I verify this? I have checked the v-card, the box, online and no
luck. Please help.
6 answers Last reply
More about first home built
  1. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    "CC" <locorican68@comcast.net> wrote in
    news:VOednWPDiZ42HincRVn-3A@comcast.com:
    > I get power to the
    > has two LED, one that indicates power supply is connected to a power
    > source, and the other indicates the system power is on). The second
    Check your case? Maybe remove the case Power On connectors and (carefully)
    short the "Power On" Pins on the mobo with a screwdriver.
    Lordy
  2. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    "CC" <locorican68@comcast.net> wrote in message
    news:VOednWPDiZ42HincRVn-3A@comcast.com...
    > Good Morning,
    not
    Can you give some more details ? 'Work' and 'not work' are a bit vague.
    Do the PSU and CPU fans turn when you press the power button ? Is it
    that the fans turn but you get no picture on the monitor ?
    How was the power supply checked ? Was it tested on another computer
    or was it manually turned to full 'on' using pin #14 ?
    > I get power to the
    two
    the
    I'm not familiar with your motherboard, but mobo LEDs generally use the
    standby 5V supply line which is separate from the main outputs. A lighted
    mobo LED is no guarantee that the PSU is OK.
    only
    That's no problem unless you want to install a very old AGP card.
    > luck. Please help.
    If you have not tested the PSU on another computer or manually forced
    it on, my suggestion is to substitute it with a known good one.
  3. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    (1) Can you give some more details ? 'Work' and 'not work' are a bit vague.
    The power supply fan does not start/run on the PC when the power button is
    pressed. The fan does not run, no picture or activity.
    (2) How was the power supply checked ? Was it tested on another computer
    I took the power supply to a local store, where they tested the power
    supply.
    > Good Morning,
    not
    the
    two
    the
    only
    > luck. Please help.
  4. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    CC wrote:
    > Good Morning,
    > luck. Please help.
    Video card can be bad.
    Memory can be bad.
    Motherboard can be grounding out. Did you mount it on standoffs so it
    does not touch the mounting plate. Grounding often causes this problem.
    You might also check how the case wires are attached to the motherboard.
  5. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    Had a similar problem with an Abit board once, when I spoke to their Tech
    guys they told me to remove the CMOS battery and reset it. It worked a treat
    the system fired up straight away. Give it a go see what happens.
    "Last Boy Scout" <eggbtr@ezl.com> wrote in message
    news:gabud.5807$tC6.1467@fe05.lga...
    > CC wrote:
    >> Good Morning,
    >> not
    >> AMD
    >> I
    >> the
    >> the
    >> two
    >> the
    >> on.
    >> only
    >> luck. Please help.
    > Memory can be bad.
  6. Archived from groups: alt.comp.hardware.homebuilt (More info?)
    Hi,
    I would Check your connection,You did plug it into the RIGHT pair of
    pins.the power supply has a Pc power select line that is activated by your
    Pc(fan/power,etc)
    and the switch,if the connection is a pin off or in the wrong location it
    will not work!
    since the PS works ok! I would look at that first,check the
    connection!common problem.
    For a newbie do this:lay the Board down on a table.
    Install the CPU/Fan on the board,plugin the fan....Install Memory.
    now plugin the Video card,connect to video display and plugin Power supply !
    turn on power supply! the light on the board will light up!OK!
    with a big flat blade screwdriver,short the two pins where you normaly
    plugin the switch on the computer,the system should powerup! if it don't,and
    nothing happens at all,other light don,t come on,no fan! you have a faulty
    board,return it for another one! this is the best way to find your way
    around the board and get used to where everything is,and find out if it
    works BEFORE you hang it in the case!(grin)
    good luck! I build them for others!
    Mine: >
    ABIT AN7 CPU Amd 3200 (400fsb)
    2x512 meg dual channel (400fsb) Pc 3200 DDR memory Winfast A400 Gt
    TDH(Nvidia Geforce 6800 256meg DDR-3 Memory. 2x SATA 120 gig 7200rpm
    Fast!
    Merry Xmas to ALL
    Dennis
    Merry Xmas
    "Matt" <matt@themattfella.zzzz.com> wrote in message
    news:XN4ud.7180$tj.1377@news01.roc.ny...
    >> the
    >> two
    >> the
    >> on.
    > Are you sure the case's on/off switch is connected correctly to the
    > motherboard and that it works? How about jumpering the on/off switch
    > directly without using the case's switch? Better yet, take the mobo out
    > of the case, and set up a minimal system (PSU, mobo, CPU w/cooler, RAM,
    > video, keyboard).
Homebuilt Systems
