Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi,
I am thinking of building a new PC, mainly for developing from home
(java/eclipse) and multimedia (digital imaging, and DV editing) (and
very little gaming)
I have few questions,
1. I am thinking of using 2 HD in raid 0 configurations, can I use only
them, or do I need an additional hard drive for the OS?
2. What types of cables do I need for the Hard drive (it's an OEM
without cables).
3. any comments about the parts I choose are more then welcomed.
4. can you recommend a good 17" LCD monitor?
Here are the parts I am considering:
Short version:
Athlon 64 +3200/K8N/2x512M/2x160G(raid 0)/DVD +/-RW 16X/ASPIRE 350W =>
$767.02
Long version:
Case:
ASPIRE X-Dreamer II Silver ATX Mid-Tower Case with 350W Power Supply,
Model "ATXB4KLW-AL/350"
Model# ATXB4KLW-AL/350W
Item # N82E16811144025
Specifications:
Case Type: Mid-Tower Case
Color: Silver
Material: Metal
Drive Bays: 4x5.25"/ 2x3.5"/ 4x3.5"Hidden
Expansion Slots: 7
Front Ports: 2 USB+Audio(Microphone Jack & Earphone Jack)
Power Supply: 350W
Cooling System: 2 x 80mm Illuminated
Motherboard Compatibility: ATX/ BABY AT
Dimensions: 17"x7.8"x16.7"
Special Features: Acrylic Added to Front Panel for polished Appearance,
Automatic Drop-Down Doors for Color Case, Extended Body for All the
Drives and Motherboards to Fit in
$54.50
Hard drive: (I am thinking of RAID 0 configuration)
2 x Hitachi 160GB 7200RPM SATA Hard Drive, Model HDS722516VLSA80 Part#
13G0254, OEM Drive Only
Model# HDS722516VLSA80
Item # N82E16822145051
Specifications:
Capacity: 160GB
Average Seek Time: 8.5 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: Serial ATA
Features: Lowest power requirements, Optional low acoustic and power
modes
Manufacturer Warranty: 1 year
Packaging: OEM Drive Only
2 x $89.88 = $179.76
p.s.
I currently own a P4-1.7/D845GBV/512M/80+120G/MSI FX5900XT, which I
built 2 years ago. I am going to use the graphics card for the new
computer, and pass the rest to my kids (theirs old PC just die).
p.s.2
I don't believe I am going to upgrade it, and I hope it will last for
atleast 18 months.
Don't get a K8N Neo! I had one and it kept losing the usb ports. I now use
an Abit AV8. I have 2 Hitachi CML174SX monitors, which are the dogs. You can
get them from www.hitachidigitalmedia.com , a good deal cheaper than
anywhere else. I would suggest getting 200GB Seagate SATA drives and RAID0
them.
> very little gaming)
For the record, I believe the P4 is better at digital video.
Nope, but you'll want to get something to backup your files to. I nice large
external USB2 or Firewire drive would do. With RAID 0 (which is not really
a RAID, technically) you increase the likelihood that something is going to
go wrong by the number of drives you have. Therefore, 2 HDD's are twice as
likely to suffer from hard drive failure. Once a drive goes down, so does
the stripe, rendering the info on the other drive completely useless.
> without cables).
Since you're using SATA, according to further down in your post, you need 2
SATA cables, and you Asus motherboard should provide them, along with some
molex to SATA power cable adapters.
Not only is a 19" CRT a better bargain, but it renders colors much more
accurately and will not suffer from any effects of pixel response time.
This may be important when editing digital video. Personally, LCD screens
are just a style thing. CRT screens have superior picture, color
management, and bang for the buck.
> Case:
> Specifications:
> Color: Silver
> Material: Metal
> Expansion Slots: 7
> Power Supply: 350W
> $54.50
Consider getting a quality power supply. No name power supplies provided by
most case makers aren't reliable enough. The PSU is one of the most
important parts on the entire computer. Many phantom problems can be traced
back to the PSU. The fact that your case only costs $54.50 with a PSU
included tells me it's going to be a junk PSU.
I recommend an Antec power supply. A TruePower 430 should be plenty.
Thanks Dud!
You saved me lots of frustration with the dual channel!
I will move up to Socket 939:
SOLTEK "SL-K8TPro-939" VIA K8T800 Pro Chipset Motherboard for AMD
Socket 939 CPU -RETAIL ($114.50)
AMD Athlon 64 3200+, 512KB L2 Cache, Socket 939 64-bit Processor -
Retail ($240.00)
About the case I decided to switch to
A-Top XBlade Black/Silver Ultimate Gaming Machine With 450W PSU & Side
window, Model "AT859A-BK" - Retail ($59.50)
About the HD I exceed my budget so I'll stick with the hitachi.. Regards,
Thanks Ruel,
Thanks for the note, I only do some home DV editing, and my current P4
1.7 worked fine, so I think the AMD can handle it
nice large
really
going to
twice as
does
Agree, adding an external HD is much easier to backup then using DVDs
(as I do now)
more
time.
screens
Couldn't agree more, I am going to use my good old 21" CRT monitor,
the LCD monitor is for my kids (space issues).
Thanks Carl,
I think I'll upgrade to Socket 939 as Dud subjected so I'll have to
replace the board too. The monitor you recommended is discontinuing...
I think I might go for its substitute CML175B. I don't have the budget
to upgrade the HD, I will add additional ATA133 HD in few months.
Regards,
On the other side of the argument, I've got a junk PSU and it's
worked flawlessly for the past few months. It came with my $35
case, so it was essentially free. Who's the fool? The one who
spends nothing on a power supply and enjoys troublefree computing
while using it, or the person who buys an expensive brand name
power supply for $60-80 and has the same experience?
