Archived from groups: alt.comp.hardware.homebuilt,microsoft.public.windowsxp.help_and_support (More info?)
I have a problem with XP Pro and a HP DDS3 C1555D tape drive it tests fine
using HP test library but fails to mount a tape using the XP backup software
I have a Seagate that works ok from XP so the software seems to be ok and
the hardware tests ok any ideas??
I could buy backup software such as Stomp but as I am a bit loathed to spend
out when the XP software backup will do all I need
Kevin
