Archived from groups: alt.comp.hardware.homebuilt (More info?)
I built my computer a year ago and everything was working fine till
today when I tried to over clock my computer, saved the BIOS settings
and since then, I'm getting continuous beeps with same intervals.
Here is my system configuration:
CPU: AMD Athlon 2500 XP
Mobo: Biostar M7NCD Pro
RAM: KByte 512MB PC3200
I've tried to reset the BIOS through CMOS jumper and by taking the
battery off for more than an hour, didn't work. I've also tried to
take off the RAM and insert it again, same nothing happened. I'm
continuously getting this beep before the POST process as soon as I
turn PC on.
Please let me know if anyone has any suggested solution to this problem.
On 16 Jan 2005 23:48:46 -0800, mohsin.nadeem@gmail.com
>turn PC on.
IN addition to what Fitz mentioned, making sure AC power is
removed, also try the (JCLK?) jumper next to the Super I/O
chip (to the left of the northbridge).
Also there might be a keyboard key you can hold in, keep
held in for a few (~4) seconds while turning on the system
to load defaults, perhaps it's the Insert, Delete, or Home
key.
Additionally, nForce2 boards seem more prone to bios
corruption when overclocking, in some cases it is necessary
to reflash the EEPROM... which of course can't be done with
that system unless it tries to boot to floppy still.
Thanks guys, I really appreciate your help.
I got another 256MB PC2700 RAM, and replaced it with my current Kbyte
512MB PC3200, and it worked on very next boot. After that, I plugged in
512MB, and it worked fine.
I don't know why, this mobo doesn't boots on 512MB PC3200 RAM if
you are messing with BIOS to do overclocking stuff. Now I do remember
it did the same thing when I built my system a year ago, I borrowed RAM
from a friend, and it worked.
So guys, here are the stable settings I came up with after overclocking
and many CPU stress tests:
On 18 Jan 2005 13:07:28 -0800, mohsin.nadeem@gmail.com
>CPU: AMD Athlon 2500+XP
>Mobo: Biostar M7NCD Pro 1.1
>RAM: Kbyte 512MB PC3200
>Multiplyer: 11
>FSB: 200 MHz
>Memory timmings: 6 - 3 - 3
>CAS Latency: 2.5
>Now this baby is running at 2.2 GHz and Windows displays it as AMD
>3200+ >
>Again, thanks for your help.
I have an M7NCG, which is the mATX version of that board but
also with the integral video. An odd quirk that I noticed
is that it is MORE stable with memory set to CAS2.5 than to
CAS3, even with CAS3 memory, even overclocked. This was
with multiple memory modules tried. I began to suspect that
the bios had somehow reversed the text strings for "CAS2.5"
and "CAS3", such that when set to CAS3 it was actually
running at 2.5, and vice-versa. Seems like I meant to
further investigate that but got pulled away on something
else, then didn't care to find out so long as it remained
error-free.
