Archived from groups: alt.comp.hardware.homebuilt (More info?)
I've just built a new pc recently so I've given my old one away.
The problem is they have just tried it and said they get the xp splash
screen then the screen goes black. I gave them the box only so they
are using their old 15inch monitor which is about 6 years old so could
it be just a compatibility problem with the monitor as the pc was
working ok for me.
When I tested it I had the resolution set to 1280x1024 and I forgot
they had a old monitor which could not handle that resolution could
that be the problem??
Athlon XP 2400
768mb pc 2100
Asus A7V8X-X Motherboard
Asus A9250/TD ATI Radeon 9250 128MB
Onboard sound
Thanks
working ok for me.
Athlon XP 2400
768mb pc 2100
Onboard sound
Thanks
