Tom's Hardware > Forum > Computer Peripherals > Printers > Sleep mode vs turn off laser printer - Brother HL-1440
Forum Computer Peripherals : Printers - Sleep mode vs turn off laser printer - Brother HL-1440
Archived from groups: comp.periphs.printers (More info?)
I recently purchased a Brother HL-1440. My first laser printer. I
have always powered off all of my inkjet printers each night or when I
did not expect to use them for several hours. My thinking was that
the power down parked the print head/cartridges and kept them from
drying out.
According to the HL-1440 user guide the printer only uses 6 watts of
power during sleep mode and there is nothing to dry out. So should I
just leave it on or power off each night? Any harm to the printer
either way? Certainly for extended periods, days/weeks, I'd turn it
off and possible unplug it if I plan to be gone for an extended time.
BrZ
Sponsored Links
In article <2op7g5Fd7e83U1@uni-berlin.de>,
> drying out.
You mean you never actually read the owner's manuals for the inkjet
printrs in question? You just decided that you must know better based
on your hunches, therefore why bother with reading the manufacturer's
specifications.
There's a lot of "my thinking was..." going on in the world, and that's
how old wives' tales come about. Then you get to have kids, and you
pass your "wisdom" on to your kids, then they turn out dumb as stumps as
well.
That's correct.
> So should I
> either way?
What does the manual say?
You have a TV and a VCR, right? Do you power those off? By power off,
I mean do you actually cut ALL power from going to those devices when
you're not using them?
No, you don't. When you hit the power button, they go to sleep. Their
internal circuitry is still alive and consuming power; they're keeping
time, channel memories, etc, and they're listening for a remote control
or internal timer code to tell them to turn on the rest of the
circuitry, fire up the tube, start the tape rolling, etc.
Look at your TV and VCR manuals, and see how much power they consume
when "off".
So you don't actually turn OFF your TV and VCR when you're not using
them, right? You don't go and hit a power strip switch or anything, or
some master power button (sometimes called a "vacation" button) on the
TV, right?
The laser printer is no different. When sleeping it's powered all the
way down except for the same bare minimum current required to keep the
circuitry alive that looks for a print job coming in. When a print job
comes in, the rest of the machine powers up and prints the job. Then it
goes back to sleep again after a few minutes.
Modern HP printers don't even have an on/off switch. The most they ever
power down is to sleep mode--just like the most your VCR ever powers
down is sleep mode. Some current is ALWAYS going through the thing.
For extended absences, unplug the thing. Otherwise, leave it plugged in
and let its internal circuitry decide when to turn the fuser and motors
on and when to leave them off.
An actual power switch isn't needed nowadays, and is overkill.
Reply to Anonymous
"Plan9" <benzplan9@hotmail.com> wrote in message
news:2op7g5Fd7e83U1@uni-berlin.de...
> drying out.
> BrZ
Don't know about the 1440 but I have a trusty 10 year old HL-660. Does your
1440 have a power button, the 660 does not.
If there's no power button leave it on as you would either have to unplug it
or have it connected to a power strip. I know that cutting the power to my
660 would cause some unfavorable results (i.e., toner on back of several
pages) the next time I printed anything. This may not be the case with your
1440, but just the same, if the manual recommends so, leave it on.
David
Reply to Anonymous
The HL-1440 is a LASER printer not inkjet
"Elmo P. Shagnasty" <elmop@nastydesigns.com> wrote in message
news:elmop-2A0493.12005521082004@text.usenetserver.com...
> > drying out.
> specifications.
> well.
> That's correct.
> > So should I
> > either way?
> when "off".
> TV, right?
Reply to Anonymous
"Russ Blakeman" <rhb57@rbcsweb.net> wrote in comp.periphs.printers:
>DO NOT put a laser printer on a UPS battery backup)
Why not?
[Please don't quote upside down, and please do trim quotes; see
<http://web.presby.edu/~nnqadmin/nnq/nquote.html>.]
Stan Brown, Oak Road Systems, Tompkins County, New York, USA
http://OakRoadSystems.com
"You want an intelligent conversation? Do what I do: talk to
yourself. It's the only way." -- /Torch Song Trilogy/
Reply to Anonymous
> Why not?
Because it has high power drainage when printing, and if generally
considered bad (like the coffee machine). The output ports
of most UPS do not protect one device from sending spikes to
the others.
If you want it on UPS, give it its own.
Povl H. Pedersen - NoSpam@my.terminal.dk (yes - it works)
Fastnet - IP telefoni: 5 kr/md Se http://www.misumi.dk
Reply to Anonymous
"Povl H. Pedersen" <povlhp@povl-h-pedersens-computer.local> wrote in
>> Why not?
>the others.
Gotcha; thanks.
My UPS has two groups of ports -- one group that simply conditions
output power, and one group that conditions power and provides power
when there's none coming from the wall. I have my printer in the
first group and all teh rest in the second group. There's been no
sign of the printer's power surge affecting any other device -- no
screen flicker, for instance.
Reply to Anonymous
Actually he has it wrong. If a UPS connects to a wall
receptacle, then the "conditioned" outlets have the same
protection as the other outlet on that wall receptacle.
Protectors do not sit between the noise and the appliance.
They are called shunt mode protector for very good reason.
The protector connects to AC mains as if it was another light
bulb. The AC mains connects directly to every appliance and
to the protector circuit equally.
There is a dirty little secret about typical plug-in UPSes
they would rather not discuss. For 120 VAC, the UPS output is
often very dirty electricity when in battery backup mode. For
example, this UPS outputs two 200 volt square waves with a 270
spike between those square waves when lightly loaded in
battery backup mode. That 270 volt spike and 200 volt square
waves is totally irrelevant to electronics which are some of
the most resilient appliances in the house. But that same 200
volt square wave - also using deceptive expressions such as
modified sine wave - can be destructive to small electric
motors.
That is correct. The appliance often sees some of the
dirtiest electricity when UPS is in battery backup mode. No
problem because electronic power supplies are so resilient.
But UPSes in battery backup mode can output high harmonics
which is not good for small electric motors. So they simply
avoid the entire topic and recommend you not put printers no a
UPS output.
For the exact same reason, those UPS manufacturers also
recommend you not put a power strip protector on a UPS output.
Either the power strip protector is degraded or the UPS is
damaged.
Again there is no magic protection blocking the appliance
from AC mains spikes. When not in battery backup mode, the
appliance is connected directly to AC mains. There is no
magic filter between AC mains and appliance - except inside
the appliance. That is correct. Any protection that works
adjacent to the electronic appliance is already inside that
appliance. Even think that UPS conditions power. Any
conditioning is so trivial as to be irrelevant. That UPS
serves one purpose - to protect data from power loss. In
which case there is no advantage to connecting a printer to
the UPS.
Stan Brown wrote:
> Gotcha; thanks.
Reply to Anonymous
- 0 +
> drying out.
specifications.
well.
That's correct.
> So should I
> either way?
when "off".
TV, right?
Sorry - I just had to respond to this person's reply. He or she seems to think that we should simply 'obey' everything manufacturers tell us and not think for ourselves. I'm sorry, but that is precisely why the world is in such a mess.
For example, when I was given a digital electricity monitor by my energy supply company last year, I discovered that my cable tv box consumes 30 watts when it's in use, and the same (!) when it's in standby mode.
Therefore, assuming it's on standby for an average of 20 hours per day, it's consuming 600 watts a day pointlessly. That's like leaving a toaster on for a whole hour, with no toast in it! Nobody would consider wasting so much energy, would they? Even a technician who came out to mend it didn't realise it wasted so much energy. Over a year it wastes an incredible 219 kilowatts.
Because it doesn't have a 'power off' switch, I went out and bought a simple remote control unit that allows me to turn it off when I'm not watching tv and when it's not set to record. The only inconvenience is a 30-second wait for it to boot up when I turn it on in the evening - hardly the end of the world - which is exactly where we're heading if people like the above don't wake up, realise what's going on and start thinking and acting for themselves.
A laser printing consuming 'only' 6 watts is probably using up 130 watts per day pointlessly (assuming 2 hours actual usage per day). That's the equivalent of leaving 6.5 100watt-equivalent energy-saving lightbulbs on for an hour, in the middle of the day. What a waste.
Manufacturers that don't provide 'power off' switches should be held to account.
Reply to gboston
There are 544 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
