G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hello,
My system:
Asus A8N-SLI deluxe mobo
Athlon 64 3500 winchester
2x512MB corsair pc3200 twinx-xl
Audigy 2 zs
2x inno3d geforce 6800GT 256MB PCI-E cards
3x SATA HDD
2x dvd drive
floppy/7in1 card reader combo
600W PSU
The case is a full sized tower with plenty of room in it. Each HDD has a
spare bay below it and they are all seated directly in front of the
front intake fan. The case is equipped with 2 120mm fans (one on the
front, one on the back). It also has a grill on the side which will seat
directly above the gfx cards.
Are the fans supplied enough to cool this beast? I'm a little worried
about the overheating issue. I don't intend to overclock at all. My
cooling options would be to mount a couple of 120mm outtake fans over
the grill on the side and/or fit some water coolers to the gfx cards.
Advice please!
Cheers,
Phil.
Hello,
My system:
Audigy 2 zs
3x SATA HDD
2x dvd drive
600W PSU
Advice please!
Cheers,
Phil.
