G
Guest
Guest
Archived from groups: alt.comp.hardware,alt.comp.hardware.homebuilt,microsoft.public.windowsxp.general (More info?)
Can a modded case with lights cause a power glitch to a hard drive that
winds up ruining the drive? Has anyone else suffered this problem?
I got a case with clear sides with lighted columns on the front and several
fans with little lights on them inside about 5 months ago. I noticed that
sometimes the little lights on the fans flickered or didn't work.
I have a C drive and a CD drive on the primary controller and 2 extra drives
for video on the secondary controller.
About a month after I started using the new case with lights, I started
hearing a screeching sound at startup sometimes and the computer couldn't
find one or both of the drives on the secondary controller. At first it was
intermittent, but the computer started reporting at bootup that the drive
had a bad status based on something called S.M.A.R.T. monitoring. Eventually
it wouldn't recognize the drive at all.
I replaced it with a SATA drive and put that on one of the SATA controllers
on the mobo. I also replaced the power supply and took out some of the lit
fans and disabled the column lights on the case.
The problem went away and the remaining drive on the secondary controller
kept working OK.
Now the same thing is happening again. I noticed that the fan with lights
was acting up and the lights were sometimes not working or flickering, and
the drive on the secondary controller has screeched a few times at startup
and a couple of times the S.M.A.R.T. monitoring has reported a bad status on
the drive and advised a backup and replacement. The drive still works.
I find it unusual that I should suddenly have these problem on two drives
after getting one of these lighted cases.
Is it possible for a case with poor implementation of these lighted columns
and fans to cause some sort of power glitch at startup that could harm a
hard drive?
Or are the two events coincidental and the drives are the ones which have
gone bad on their own?
Could the secondary controller on the mobo be at fault?
So far the problem has only involved a couple of 40 gig maxtor drives that
were on the secondary controller and none of the other drives.
Has anyone had a similar problem?
Thanks a lot for any advice.
I have win xp as the operating system.
kept working OK.
hard drive?
