Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Power supply value for $
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Will I get value for money with a name brand power supply over a no
name one? I can pay 3x more a one with the more maketing hype. Or will
the extra $ be worth ut?
cheers Kevin
Sponsored Links
On 8 Feb 2005 23:32:58 -0800, kevin_nzl88@hotmail.com (Kevin
>name one?
Yes but it's not just about value for money, it's also about
accurate wattage ratings, safety features and component
quality at least high enough for good lifespan. Power
supplies should be unobtrustive, you're not necessarily
buying "value" rather than needed function per the system.
To put it another way, suppose you buy a 500W generic worth
only 250W. If your system only needed 250W and the
amperage:rail distribution was right you might get good
value from it, accidentally rather than purposefully unless
you knew through testing the exact qualities of brand "x"
generic. This ignores any potential safety features, if
there were a problem there could still be a more costly
recovery from failure of power supply or other components.
Comparison of specific units must be considered, they can't
simply be lumped together as "3X more... marketing hype" vs.
generic. Some commercially marketed PSU are better than
others. Even more sobering is that most of the best
name-brand power supplies have very little marketing at all,
don't need to be pushed on buyers. Zippy, Delta, Fortron,
et al are not marketed much if at all for retail sales.
Delta is the largest and yet most aren't even familiar with
their products, being found mostly in servers, workstations
and OEM proprietary casing sizes... but due to OEM usage
they have a large PC presence.
It is a question of what you actually get for the money as
much as the amount of $. So yes, it is easily worth 3X, or
even 10,000X more for the better unit _IF_ you need the
wattage. Buying a generic with 550W stamped on it's label
isn't any assurance that is a sustained value rather than a
peak, and such practices should be illegal, IMO.
Applying towards a purchase, determine the needed capacity
per system. If you can't determine whether brand X model Y
is accurately rated for sustained output, you'd then be
gambling on whether it's true output and features are
sufficient. IMO, unless you MUST have fancy eye-candy the
best value on PSU are Sparkle/Fortron, particularly in the
400W-530W range there is nothing of same quality at same (or
lower) price-points when purchased online. In retail stores
the pricing on PSU varies so wildly that it must be
ignored... unless there is an emergency such that a
replacment must be had immediately.
Reply to Anonymous
"Kevin K" <kevin_nzl88@hotmail.com> wrote in message
news:607636b9.0502082332.13f03d14@posting.google.com...
Yes.
Derek
Reply to Anonymous
The name brand units (Antec is the best) are built to much higher specs and
more conservatively rated. They use MUCH higher quality parts.
DaveW
> cheers Kevin
Reply to Anonymous
Type "Seasonic" into Google and read the reviews on it. I just
purchased one to replace my Antec.
Reply to Kram
Amusingly enough, the only ATX PSU I've had go belly up was an Antec.
Reply to Anonymous
I get kind of miffed about this one. I wish there was a simple way to
benchmark PS output. It seems like a lot of companies cheeze out on the
PS.
Sure, you might have ROOM in the case to expand your system, but you
almost always void your warranty by opening the case, so there's no real
incentive for the manufacturer to provide a healthy power supply for
whatever upgrades you might be considering.
Reply to Anonymous
On Thu, 10 Feb 2005 04:11:42 -0600, David Maynard <dNOTmayn@ev1.net>
put finger to keyboard and composed:
I'm not surprised. Most people who wax lyrical about "quality" have
never looked beyond the price tag. Their solitary pearl of wisdom is
that tired old mantra, "you get what you pay for". Blah, blah, blah.
Call me a cynic, but I don't see too much difference between a generic
PSU and a supposedly reputable one. I've repaired too much
electronics, of all makes, and in all manner of equipment, at both
ends of the market, to be swayed by hype and FUD.
- Franc Zabkar
Please remove one 's' from my address when replying by email.
Reply to Anonymous
I buy the cheap ones, but I always buy more power than I need. I never buy
anything under 400 Watts and I have not had problems, I have only had the
one for about four to six months, but it works great and it was cheaper than
ones rated less. You get what you pay for, sometimes, but if all else
fails, overbuy. My new computer which I'm building on Monday has a 450 watt
power supply included in the case. But always be careful, if the power
supply is not powerful enough you may have six months of worry free service
and BAM your killing hard drives left and right. A good Seagate may still
be usable, but you will get bad sectors, but the SMART will be OK on the
drive afterwords. Case and point:
My uncle fully loaded his Gateway with a CD Burner and a 20 Gig Hard drive
(I have the hard drive now). But only a 90 Watt power supply.
I am called to fix a video driver problem, find out the OS is screwed up and
reformat to find BAD sectors. He buys and 80 gig maxtor and I installed it.
Four months later System was messed up, formated hard drive, BAD SECTORS
again. I talked to a friend about it and he said it was the power supply.
My uncle and I go on the Internet and buy a 40 Gig drive (he never filled
his 20 Gig), power supply and case fan. Everything was later installed with
no problems (except a power supply screw hole mismatch on the propretary
power supply, but it works). I have only had to get rid of spyware and
install a TV tuner since.
"Franc Zabkar" <fzabkar@optussnet.com.au> wrote in message
news:o64q01lllkrhpseo0togevi0nksomvmpk5@4ax.com...
and
> - Franc Zabkar
Reply to Anonymous
Well, one of the biggest problems with 'el-cheapos' is you're seldom, if
ever, getting what you think you are and the wattage ratings on them mean
practically nothing. A "400 watt" labeled el-cheapo can be almost anything,
except 400 watts.
Reply to Anonymous
Kevin K:
http://www.hardforum.com/showthread.php?t=792566
http://www.hardforum.com/forumdisplay.php?f=93
Mac Cool
Reply to Anonymous
I concur, I have a Fortron 530...
"kony" <spam@spam.com> wrote in message
news:9oqj01hgbj1h9c1jlmk5ar4rms8c637fg0@4ax.com...
> >name one?
Reply to dos
Antecs aren't the best.
"DaveW" <none@zero.org> wrote in message
news:08WdnWQj9ewjPpffRVn-rA@comcast.com...
and
> DaveW
> > cheers Kevin
Reply to dos
There are 893 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
