Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi,
I've just purchased a load of bits, including an Antec Sonata case
(lurvily!!) and an Asus A8V-E deluxe motherboard.
However, it appears I have a problem.. well I hope not, but if anyone
can help I'd be grateful.
On the motherboard, there is a 24 pin 'EATXPWR' connector and a 4 pin
ATX12V connector. It says that an ATX 12V specification 2.0 compliant
PSU should be used (which I thought mine was..).
However, on the Antec case/380W PSU, there is a 20 pin (!!) main power
connector, a 6 pin AUX connector and a 4 pin ATX12V connector.
HELP! These don't seem to match up. Any ideas? Do I need a different
PSU? Or is there an adaptor available..
"Dave" <davehowey@hotmail.co.uk> wrote in message
news01t2q$9il$1@jura.cc.ic.ac.uk...
> Hi,
> However, it appears I have a problem.. well I hope not, but if anyone can
> ATX12V connector. It says that an ATX 12V specification 2.0 compliant PSU
> HELP! These don't seem to match up. Any ideas? Do I need a different PSU?
I just got an Asus A8N SLI-Deluxe... it also has the new EATX 24-pin plug
with the additional 4-pin connector..
I buckled down and got a 510W SLI P/S from PC Power and Cooling.. It has an
adaptor BACK to 20-pin, but I am pretty sure you can't hook up an old ATX
P/S to a 24-pin board.
Another excellent supply is the 480W NeoPower from Antec.. it has connectors
for both 24-pin and 20-pin boards.
> Good Luck
Actually, I've been doing some research and I think that as long as your
PCI express power requirements are modest (and mine are-- 380W is more
than enough for 2x80Gb HDDs, 1x FX330 PCI-E fgx card), you can plug the
20 pin connector into the 24 pin connector on the motherboard. I've
emailed Antec to double check, and I'm also just comparing connector
pin-outs, but I think it's ok.
See
http://forums.pcper.com/showthread.php?t=376129
20 pin pugs do fit into 24pin plugs. My new MB cam with a sticker over
the last 4 pins. It's says to remove the sticker if the power supply
has 24 pin plug.
cheers
Kevin
> See
> http://forums.pcper.com/showthread.php?t=376129 >
> Anyone else tried this?
> Dave
Just plugged it all in.. and it works. PHEW!
CPU temp around 37degC, ambient inside case around 32degC. Everything
seems to be ok at present, now I just need to install some operating
systems!
