Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Hard Drive problem: won't boot or work as a Slave
Forum Homebuilt Systems : General Homebuilt - Hard Drive problem: won't boot or work as a Slave
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Have a Western Digital that stopped booting. It hangs at the Windows
XP spash screen, with the scroll bar running beneath it. When trying
to boot to safe mode, it hangs as it's loading .sys files from the
drivers folder (last one listed is amdagp.sys). I can see it in the
bios, and I've run a WD diagnostic tool and another one on it and they
say it's fine. I'm guessing the MBR might need fixing.
But the real problem is I put it in another system as a slave and it
keeps that one from booting up, too. Same problem with getting to safe
mode and a prompt, except that it hangs at agpcpq.sys.
Any thoughts, on at least being able to access it as a slave from a
prompt so I could try to repair it, or at least save the data? TIA!
Sponsored Links
If the OS is Win95, Win98(SE), WinME, you can try booting with a floppy
and doing "fdisk /mbr" at the A: prompt. If that doesn't solve your
problem, then read the next 2 paragraphs.
If you have data on that drive that you need to recover, then install a
second drive, as the master Boot drive, and see if you can read the
current drive. If you can read it, backup the critical data and then
reformat the drive.
If you have no data that is critical to recover on this drive, then
reformat the drive and re-install you operating system.
Reply to Dee
- 0 +
>reformat the drive.
Sorry that my initial message got convoluted and confusing. I'm
running Win XP (Pro on the problem drive, Home on the second system).
I tried and am unable to Slave the problem one to the second system,
or I imagine, as you suggest, to put a new master one in the problem
system. The problem drive causes the second system to not boot, and
I'm sure would do the same if I put a Master into the problem system
and Slaved the problem HD there. I just can't get a machine to boot,
even to a (dos) prompt, when this HD is in the system, even Slaved.
Reply to Jack
"jack" <a@b.com> wrote in message
news:lerc21ha427epjrd1o1s3pprjmf3fj2i9u@4ax.com...
You might try getting an external USB Drive Enclosure, they run about 50 or
60 bucks.. good thing to have around anyway for older drives that you want
to use as quick swap data backups.. with the drive in a USB Box you can just
plug it in to a USB port, and if it is working at all it will pop up without
having to reboot your system.
Reply to Anonymous
For me it look like that is mish mash with jumpers (master - slave) on HD.
Boba Vancouver
"Morituri-|-Max" <newage@sendarico.net> wrote in message
news:noxVd.10225$SQ4.1171@fe1.texas.rr.com...
> or 60 bucks.. good thing to have around anyway for older drives that you
> want to use as quick swap data backups.. with the drive in a USB Box you
> can just plug it in to a USB port, and if it is working at all it will pop
> up without having to reboot your system.
Reply to Anonymous
- 0 +
On Thu, 03 Mar 2005 05:37:23 GMT, "Morituri-|-Max"
Thanks, I'll try that. I had tried "hot swapping" on the channel after
it booted and, not surprisingly I guess, it just locked up. Probably
lucky it didn't do worse, but I was desperate! I wasn't aware of
USB-based enclosures. Thanks again.
Reply to Jack
- 0 +
On Thu, 03 Mar 2005 05:55:24 GMT, "Boba & Ilinka"
>Boba Vancouver
If you mean that I don't have it jumpered right, no, that's not it.
Thanks anyway.
Reply to Jack
You do realise that the jumper for Western Digital drives are
different if you have master only against having a slave as well.
3 seperate settings - Master only - Master with Slave - Slave
DJT
Reply to Anonymous
- 0 +
>DJT
The WD is the slave on the Primary channel with the Master boot drive
(which isn't WD), where I'm unable to boot it into the second system.
So the Slave is the only choice. I'll make note of your point though
when putting it back into the original system, where it was the Master
of a Master-Slave combo. Thanks.
Reply to Jack
There are 658 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
