Archived from groups: alt.comp.hardware.homebuilt (More info?)
"David" <davidcleland@hotmail.com> wrote in message
news0fmn7$66h$1@news.freedom2surf.net...
> anyone using the Gigabyte GA-K8NXP-SLI, ATX, DDDR400, PCI-E, Gbit Lan, USB
> 2.0, 1394, AC'97 Audio, 8 x SATA, Raid
> just everything I start up from cold it restarts again. I turned on errors
> and it blue screens to say IRQ must be equal or something ? any ideas ?
> I have disconnected everything but HD, memory and gfx cards and it still
> happens
> David
Yes power supply 5 volts is not stable enough, you must have a good 400
watts or greater PSU which can supply at least 2.0A on the 5volt rail.
Chris
Technical director CKCCOMPUSCRIPT
Apple Computers, Intel, Roland audio, ATI, Microsoft, Sun Solaris, Cisco and
Silicone Graphics.
Wholesale distributor and specialist audio visual computers and servers
FREE SUPPORT @,
http://www.ckccomp.plus.com/site/page.HTM ckccomp25@hotmail.com
>> happens
I have a good PSU, it is +5v and is says 30A ? there is a gigabyte power
add-on I have installed with blue lights - but as you can see I am a techo
idiot so can not describe these things well.
On Sun, 6 Mar 2005 21:47:41 -0000, "David"
>>> happens
>David
Many board now ( maybe yours too?) use more 12V power than
5V. An amerage rating on a label may not be evidence of an
actual capacity as some makes have deceptive labels/specs of
only peak capacity (and even then seem overrated). If this
is a generic power supply the odds are good it needs
replaced. Take voltage readings with a multimeter.
> happens
> David
Yes +5 volt VSB should be 2.0A not the +5 Volt rail. other than the actual
external drives CD/DVD/HDD the mother boards draw very little on the 12v
side really, I have some 650 watt N+1 dual hot swap PSU's here and they are
unable to power an Athlon 64 system or the LGA775 P4 as they only deliver
1.0a on the +5 Volt VSB. Symptoms are exactly as you describe, yet a single
680 watt Thermaltake W0049 PSU has no problems at all if you follow the link
you will see the +5 Volt VSB is 2.0A.
Chris
Silicone Graphics.
FREE SUPPORT @,
"Chris17" wrote:
> http://www.ckccomp.plus.com/site/page.HTM > ckccomp25@hotmail.com
> Gbit Lan, USB
> turned on errors
> any ideas ?
> and it still
> > happens
> > David
> than the actual
> on the 12v
> and they are
> only deliver
> yet a single
> follow the link
> http://www.thermaltake.com/purepow [...] atx12v.htm >
> Chris
> Solaris, Cisco and
> Silicone Graphics.
> and servers
> FREE SUPPORT @,
I too am using this board and I’m having the exact same trouble using
XP with SP2. I’m yet to try a reinstall or other things, but nforce4
platform drivers from the nvidia site have proven to be innefective of
curing this problem.
The fact it’s bringing up an IRQ not equal to or something means it’s
an IRQ thing i know that, as to what’s causing it I’m yet to figure it
out.
darthmeow wrote:
> "Chris17" wrote:
> > http://www.ckccomp.plus.com/site/page.HTM > > ckccomp25@hotmail.com
> > Gbit Lan, USB
> > turned on errors
> > any ideas ?
> > and it still
> > > happens
> > > David
> > than the actual
> > on the 12v
> > and they are
> > only deliver
> > yet a single
> > follow the link
> > http://www.thermaltake.com/purepow [...] atx12v.htm > >
> > Chris
> > Solaris, Cisco and
> > Silicone Graphics.
> > and servers
> > FREE SUPPORT @,
> out.
