G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I am looking for a rounded *40* pin IDE cable to replace the only flat
ribbon cable I have in my custom rig. This flat ribbon cable really stands
out in my modded windowed
case.
This *40* pin flat ribbon data /interface cable was supplied with my I/O
Flex FireWire& Hi-Speed USB2.0 Controller card.
The cable comes up from the PCI card to a 3.5" front panel module on my
Antec SX635 Mini Tower Case, which at the time I bought it had NO provision
for front panel USB etc.
Now before you say "just use an 80 pin rounded cable" I have, and it does
NOT work !!
In this case, I need to find a *40 pin* ROUNDED IDE cable.
I have tried other regular 40 pin flat ribbon cables and they work, so it
isn`t some special cable other than being just a 40 pin.
I have even tried "backword compatable" Rounded cables, but here again they
are 80 pin! For whatever reason this data cable *must* be 40 pin.
Any ideas here... this ribbon cable has been bugging me for awhile now.
Thanks in advance
Matt
case.
NOT work !!
Thanks in advance
Matt
