Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > WinXP installation - Probably hardware problem
Forum Homebuilt Systems : General Homebuilt - WinXP installation - Probably hardware problem
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Problem installing Operating system.
I am experiencing a problem installing WinXP on a home built system. I am
pretty sure that the problem is hardware related, but I can't locate the
issue.
The system has a MSI KT4V motherboard, a Western Digital 120GB hard drive,
with a 100GB Western Digital drive as slave on the same EIDE channel, and an
Nvidia 6600video card and 1 gig of PC266 RAM.
My problem is that I cannot seem to install Windows XP. After formatting
the main hard drive in FAT 32 using Ghost's Gdrive utility, I boot into DOS
and load smart drive and try to load the WINNT setup program under the I386
folder for WinXP.
This process has functioned fine many times, but in the case of this current
setup, it freezes up while loading files onto the hard drive needed to
install. It never succeeds in leaving the DOS segment of the install
process.
I'm not sure if the problem is with the hard drive (it is a new drive) or
some defect in the motherboard.
I would be grateful for any advice!
Sponsored Links
On Wed, 16 Mar 2005 21:37:34 -0600, "pj"
>issue.
>folder for WinXP.
>process.
1) Recheck your media. If it's a CDR, maybe it's gone bad.
Maybe the files on the drive are corrupted... recopy them
and try again.
2) Test the memory for several hours with memtest86
3) Check heatsink-CPU interface, fans spinning, temp, and
voltages. If you have a multimeter, use it. Do you have a
decent name-brand power supply?
4) Reset bios to defaults. Clear CMOS via jumper. Then if
it doesn't help, see if underclocking improves things.
5) Run the HDD manufacturer's diagnostic utility (floppy or
CDR) available from their website. Check cables, data and
power, and the seating of cards, memory, etc. Some of this
may be unnecessary but you didn't mention the history of the
system so we're guessing a bit, and/or covering all bases.
6) Remove all but 1 memory module, all "unnecessary"
(towards merely installing windows) cards, all USB devices
(except mouse and/or keyboard if you MUST use USB type), and
all onboard features on the motherboard, including secondary
drive controllers, sound, lan, firewire, etc. Leave the
floppy drive connected but disconnect the CDROM after you're
sure you have intact/uncorrupt I386 folder on the HDD.
Has winxp ever successfully installed on this system?
Check for a bios update for the motherboard, but flash only
if it seems stable (except for winxp installation of
course).
Reply to Anonymous
"pj" <pjenrow@hotmail.com> wrote in message
news:VJSdnaJ9btbjZqXfRVn-pA@comcast.com...
> issue.
> an Nvidia 6600video card and 1 gig of PC266 RAM.
> DOS and load smart drive and try to load the WINNT setup program under the
> I386 folder for WinXP.
You are using the WINNT32 setup, correct? :-)
> current setup, it freezes up while loading files onto the hard drive
> needed to install. It never succeeds in leaving the DOS segment of the
> install process.
Reply to Anonymous
On Thu, 17 Mar 2005 04:40:56 GMT, "John E. Carty"
Err, in DOS it would be winnt, not winnt32
Reply to Anonymous
pj writes:
Try doing a standard setup of XP instead of a hacked one.
Transpose hotmail and mxsmanic in my e-mail address to reach me directly.
Reply to Anonymous
- 0 +
Hi Kony,
Many thanks for the great suggestions.
I believe the media is OK, since I have had the same problem using 2
original DVD sources as well as a CDR version. I have not tried to copy the
i386 directory to the target disk yet, but I thought that if I was having
this odd problem, it would be a good idea to resolve it first.
I have an Altec 400w power supply,which should be more than adequate for the
system. I have ordered a tester for the PSU, so I can hopefully rule out a
problem there. All fans are running fine and the bios screen indicates that
the temperature is not a problem (low 40s). The memory appears to be seated
fine given the successful memory test. I intend to run memtest to double
check though.
Neither WinXP or any other OS has ever been installed on this system as it
is essentially new. The MB CPU combination is new as is the hard drive.
Thanks again, and I will post the results of these tests.
Paul
"kony" <spam@spam.com> wrote in message
news:1j1i31t3brrpeuqltngldkm8vvomlh395v@4ax.com...
>>issue.
>>an
>>DOS
>>I386
>>folder for WinXP.
>>current
>>process.
> and try again.
> course).
Reply to pj
On Wed, 16 Mar 2005 23:05:09 -0600, "pj"
<snip>
>system.
?? Who makes Altec? Sounds a bit like a generic, in which
case it might not be safe to assume it's actually capable of
400W. Could be, but insufficient info to determine.
>problem there.
If it's the simple plug-in type that does little more than
put a minimal load on 5V rail and short PS-On to ground, it
is not really going to "test" anything more than a basic
minimal function of the unit, not that it's actually
operating properly let alone suitable for the system. In
such cases a multimeter can be used to take voltage readings
at the connection (connector) to the load, that being where
it connects to the motherboard while the system is "on".
Even then, in some cases the only reliable test is to swap
in a PSU known adequate per system type and working
properly.
Reply to Anonymous
pj wrote:
> Hi Kony,
> check though.
Why aren't you booting from the CD and doing the install the normal way?
Reply to Anonymous
On Thu, 17 Mar 2005 10:26:03 -0600, David Maynard
Why would anyone prefer to boot from the CD if they know how
to do it better?
I never use the CD, installing from folder on HDD should not
be an issue and I'm puzzled why you and another poster have
brought this up. Perhaps if it read from the CD, it would
install so slowly that the CPU wasn't as utilized and that
might mask other problems like overheating or poor power,
but doing so would not be a solution, merely increasing odds
of having a seemingly correct installation that had been
corrupt.
Reply to Anonymous
kony writes:
> to do it better?
The usual reason for not booting from the CD is that the software is
pirated.
Reply to Anonymous
Because it's simple.
> if they know how to do it better?
He wasn't doing the "better" version. He didn't copy the files to the hard
drive and invoke setup. He formatted the drive, put DOS and smartdrive on
it, and then invoked winnt from the CD folder.
That's going to a lot of work, with the potential for errors, to accomplish
the exact same thing booting from the CD does.
> be an issue
I often install from the hard drive too.
> brought this up.
Because he gains nothing by the method he chose and since he did all that
work just to recreate a CD boot, and then install from the CD, I simply
wondered why he didn't just boot from the CD.
> corrupt.
I think the miscommunication here is you are presuming he copied the files
over, like you and I would, when he specifically said he didn't do that.
Reply to Anonymous
On Thu, 17 Mar 2005 20:31:30 +0100, Mxsmanic
<mxsmanic@hotmail.com> wrote:
>kony writes:
>> to do it better?
>pirated.
Do you have any evidence of this?
Businesses install over lan all the time. Actually anyone
who's been around a while knows it's better to have the
source OS files already on the HDD so the OS doesn't look
for them later, plus it installs SO much faster.
Do you really thing someone competent enough to pirate XP,
to get it and circumvent the activation, isn't able to do
something as simple as burn a CDR? Of all the possible
reasons why someone would or wouldn't boot to CD, yours
seems quite low on the list... or maybe I"m wrong, I've
never hear of anyone claiming "I pirated it so I have to
install from HDD".
Reply to Anonymous
On Thu, 17 Mar 2005 15:28:04 -0600, David Maynard
Ok, sorry, should have read more carefully.
Reply to Anonymous
The PROPER way to load XP onto a new machine is to set the BIOS to boot 1st
from the CD-ROM, then insert the XP CD and reboot. The computer will boot
from the XP CD and you then just follow the directions.
DaveW
> issue.
> install process.
Reply to Anonymous
- 0 +
Thanks everyone for the advice.
I was a bit too tired when I posted last night and wrote that the psu was
Altec. Of course I meant Antec (I could imagine some knock-off PSU named
Altec though).
The reason I was not using a boot from the CD rather than booting the system
from a DOS floppy and loading smartdrive seperately was mostly just a bad
habit I got into. While the DVDs from MSDN are supposed to be bootable, it
appears that I would have to switch the order of my CD / DVD drives to get
the DVD drive to be recognized as bootable. So I am a little lazy (or stuck
in a rut) and just boot to DOS with CD/DVD drivers and launch the Winnt.exe
that way. I hadn't considered this as an important step to try since I had
used this procedure to install XP on another computer (the one I am using
now) just a week ago, and it worked fine.
I get my WinXP from a DVD with a number of other OS's since I had a MSDN
subscription, and this is the way it came. It certainly isn't pirated.
I ran memtest89 last night and it indicated a large number of memory errors,
The memory (DDR 266 PC 2100) is generic, and it might not be up to the
higher bus speed. I tried clocking down to 100mhz FSB, but still got the
same errors. The hard drive tests returned no problems.
Thanks again for the advice.
Reply to pj
news:gsjj31hlcl93cmtqrd3a35pn6jk8j1cbst@4ax.com...
> to do it better?
Uh, because in this case it "don't" work better. Why no try it the stupid
way once to see if that works better?
8 )
Reply to Anonymous
news:g14k31145keb1qf3bvrqipm9r37l8kpc6t@4ax.com...
>>accomplish
Heh... even the computer Ueber-Gurus have bad days.
Reply to Anonymous
news:P9OdnSer-qMpyaffRVn-rA@comcast.com...
> Altec though).
> system from a DOS floppy and loading smartdrive seperately was mostly just
> a bad habit I got into. While the DVDs from MSDN are supposed to be
> bootable, it appears that I would have to switch the order of my CD / DVD
> drives to get the DVD drive to be recognized as bootable. So I am a
> little lazy (or stuck in a rut) and just boot to DOS with CD/DVD drivers
> and launch the Winnt.exe that way. I hadn't considered this as an
> important step to try since I had used this procedure to install XP on
> another computer (the one I am using now) just a week ago, and it worked
> fine.
> errors, The memory (DDR 266 PC 2100) is generic, and it might not be up to
> the higher bus speed. I tried clocking down to 100mhz FSB, but still got
> the same errors. The hard drive tests returned no problems.
Very cool... I'm glad (as an interested observer) that you are a little
closer to isolating your problems.
Good luck.
Reply to Anonymous
On Fri, 18 Mar 2005 08:41:16 GMT, "Morituri-|-Max"
>> to do it better?
>8 )
But, you imply it makes a difference. If the PC works
properly this should make no difference... so if it does
work the 'stupid' way, it may get windows installed but the
problem remains... or it may corrupt windows and OP is
running an OS that keeps crashing and will never get it
running right, chasing around not only the original problem
but then also a corrupt OS. Adding more problems makes
troubleshooting MUCH harder.
On the other hand, sure it could be tried, the install could
finish, maybe then more diagnostics software can be
loaded.... but if there is ANY CPU or memory, chipset
instability then it would be prudent to fix that and THEN
start over reinstalling windows clean, not overtop of itself
and not a repair.
Reply to Anonymous
On Sat, 19 Mar 2005 19:46:43 GMT, "Baad Boy"
<Boybaad@hotmail.com> wrote:
>...just as I said before, "argue as though they are the supreme right".
It's not about "... they", it's about a workable solution.
Pretty easy to come across people with attitudes, but in the
end the argument "should" be towards that solution.
If you don't like usenet there are other places to be?
Reply to Anonymous
- 0 +
A word of support for kony.
I have dipped into this Newsgroup many times in the past and feel that
any input from kony is the one to favour.
Whenever "embelishments" are put in a response I feel that they are
worth having if it allows the poster to fully explain his position.
I would rather have a "long winded" reply from kony than none at all.
KM
Reply to km
There are 554 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
