Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > power crash on new PC OS installation and now games
Forum Homebuilt Systems : General Homebuilt - power crash on new PC OS installation and now games
Archived from groups: alt.comp.hardware.homebuilt (More info?)
morning all.
Just built a pc with all new gear except using old floppy and old case.
Terrible trouble installing OS, either XP or 98 as machine switched
self off during installation at variable places of the process. I
persisted ( foolishly?); replugging, reconnecting, blowing on plugs,etc
etc. I even bought a new case, thinking perhaps it was my powerswitch on
my old case that was faulty. Things seemed sorted and I finally
installed XPPro. Finally now I have WinXP Pro running OK I think,
except that when I log into online game Everquest, the same problem
happens, the machine just powers off. Needs about a minute before boot
is possible.
AMD 64 3000 with provided cooler and fan
2 x 500mb DIMM 400 twinmos branded
asus A8N-SLI 64bit
sparkle GeForce 6600GT PCI Express 128mb
550w powersupply atx colorsit big fan
DVD writer
CD writer
160gb Maxtor sata
IIyama visionmaster pro 454 19" CRT
I checked temp of MB and of CPU with asus probe, and thats OK, as well
as MB voltages etc. Fans working OK.
I have tried plugging extra power for the PCI-E card to the MB, and that
makes no difference. MB manual says that extra power supply is only
when using two graphics cards anyway.
As my current craze is trying to continue playing Everquest2... I am
getting pretty frustrated.
I would be grateful for any suggestions at all !!
Pat
Sponsored Links
"pat" <neukuk@yahoo.co.uk> wrote in message
news:gzQ0e.2884$4%3.164@fe2.news.blueyonder.co.uk...
> morning all.
> Terrible trouble installing OS, either XP or 98 as machine switched self
> off during installation at variable places of the process. I persisted
> ( foolishly?); replugging, reconnecting, blowing on plugs,etc etc. I even
> bought a new case, thinking perhaps it was my powerswitch on my old case
> that was faulty. Things seemed sorted and I finally installed XPPro.
> Finally now I have WinXP Pro running OK I think, except that when I log
> into online game Everquest, the same problem happens, the machine just
> powers off. Needs about a minute before boot is possible.
> asus A8N-SLI 64bit
> DVD writer
> CD writer
> 160gb Maxtor sata
> I checked temp of MB and of CPU with asus probe, and thats OK, as well as
> makes no difference. MB manual says that extra power supply is only when
> Pat
hi pat,
i would check that u have the correct standoffs under your board as any
misplaced ones may cause a short.
hth john
Reply to john
- 0 +
> morning all.
> asus A8N-SLI 64bit
> DVD writer
> CD writer
> 160gb Maxtor sata
> Pat
That PSU isn't a QTEC by any chance is it?
SteveH
Reply to steveh
- 0 +
>>morning all.
>>asus A8N-SLI 64bit
>>DVD writer
>>CD writer
>>160gb Maxtor sata
>>Pat
> SteveH
PSU is Colorsit 550...never heard of them. could a poor supply explain
all the installation probs and the current probs running intensive
internet game?
I reinstalled the motherboard in new case, the widgets look ok
underneath....
and everything closed o course today...
Thanks
Reply to pat
- 0 +
news:SMX0e.2881$IH3.1491@fe3.news.blueyonder.co.uk...
>>>morning all.
>>>asus A8N-SLI 64bit
>>>DVD writer
>>>CD writer
>>>160gb Maxtor sata
>>>Pat
>> SteveH
> internet game?
> underneath....
> Thanks
It may not be the only reason, but a cheapo PSU like that is the first thing
I would suspect. It's never worth economising on the PSU, in the long run.
SteveH
Reply to steveh
- 0 +
Thanks to all o you
Aftere taking my PUnit to ths shop, they tested and found it fine.
I found a helpful mate, who tested my machine and YES it wa the power unit.
Thanks a million
Pat
Reply to pat
There are 1012 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
